37 chevy fenders
Discussion in 'The Hokey Ass Message Board' started by wing man, Jan 15, 2007.
  1. wing man
    wing man
    Hi i am new here have been reading a while you guys are a wealth of knowledge thanks all of you.
    I am tring to up a 37 chevy together I got a free 1 ton truck less box. but want to make a 1/2 ton are the front fenders diffent from 1ton to half ton if so how much.
    I have been looking on the web for days now but have had no luck finding out even tried to search here.
    Thanks for your help
  2. TagMan
    TagMan
    According to the 1937 Engineering Features book I have, the '37 1/2T front tread width is 56-3/8", while the 1-1/2T is 58-1/16" wide.
    The fenders have different part numbers, so most likely not interchangable.
  3. The 3/4, 1, and 1 1/2 ton models all share the same cab and doors. Thats where the simularities end. Beyond that the front fenders, grills, hoods, and frames are all streched and supersized to fit the tall ties and oversized radiators for pulling the heavy loads. Hope this helps you some. Also check out stovebolt.com, they have some info on these trucks and a gallary dedicated to early Chevy trucks.
  4. junkyardjeff
    junkyardjeff
    While trying to find good steel fenders for my 37 1/2 ton I found a few NOS fenders for the big trucks,from what I have seen the opening for the wheel is larger on the big truck fenders then on the 1/2 tons. I never found any good steel 1/2 ton fenders and went with fiberglass. Jeff
  5. wing man
    wing man
    Thank you guys for your help. I am going to put this cab on a s10 frame because I have one also have two boxs that are 1/2 ton.
    Thank you guys for your help:)
