Technical '37 Ford Radius Rods strong enough?
Discussion in 'The Hokey Ass Message Board' started by Shaun1162, Jun 1, 2014.
  1. Shaun1162
    Shaun1162
    Hey guys, I've been reading this old Tech Article done by Samlyam about wishbone suspension in a car with open drive. I have a '37 rearend that I plan on using (converting it to open drive of course), but I'm curious if they '37 radius rods are strong enough, or if I should try to find some '35/'36 radius rods.
  2. onekoolkat1950
    onekoolkat1950
    ImageUploadedByH.A.M.B.1401634594.620597.jpg shaun here's a set I made and installed on a 34 coupe just add a top bar and a gusset and they are plenty strong. You can use them as is as long as you run a torque arm from the rear to a center member or tie them together with a ball joint or heim at the front..
  3. Here's on I did using them with a torque arm.
  4. Shaun1162
    Shaun1162
    Thanks for the help! I think I'll leave them as-is and then run a torque arm from the center section, that should be the easiest.
    Hey Ray, how's your roadster coming?
  5. jseery
    jseery
    from Wichita KS
    Yep, the year of the radius rods do not make a difference, it is the lack of an additional rod to the upper side of the axle to replace the support function of the torque tube that is the issue.
  6. onekoolkat1950
    onekoolkat1950
    Haven't started on the T yet Shaun . Replace a blown clutch and the trans in my 28. Hope to start the T in the next few weeks , I most of the parts. Good luck with your build, let me know if you need anything -Ray
