'37 Ford steering completed
Discussion in 'The Hokey Ass Message Board' started by TNDoug, Dec 23, 2012.
  1. TNDoug
    TNDoug
    from tennessee
    Just finished up converting my '37 Ford to a saginaw 525 box. What an improvement! My old original box was always hard to steer no matter what I did to adjust it. The saginaw setup went really easy. Thanks to all in this forum for the advice.
  2. bubbajla
    bubbajla
    from Rogers, AR
    Do you have any pics? I am getting ready to do the same thing to my 37...would appreciate any info
  3. joel
    joel
    Here are some pics of the box installed in my 40 using brackets from Ch***is Engineering. The pitman arm is aftermarket for the pwr box that I bent to better align the drag link. Middle pic is showing the CE mounting plate & pitman arm. In the last pic I tried to show the space between the block and steering box.
  4. brigrat
    brigrat
    from Wa.St.
    Wanna sell your '37 box?
    What is a Saginaw 525 box off of?
  5. TNDoug
    TNDoug
    from tennessee
    My '37 box was shot. The worm gear is pitted but the sector shaft was okay. I've listed it on another site. The 525 box was from a mid 60's GM front clip that I found behind a mobile home. The best part was that my pitman arm from my old box fit right onto the 525. I bought a bracket from Ch***is Engineering and one steering joint and a coupling from 3/4 round to 36 spline. The whole job took less than 2 hours.
