Projects '37 FORD TRUCK / 348 W MOTOR (FULL BUILD P.1-11)
Discussion in 'Traditional Hot Rods' started by '37-4D, Feb 23, 2017.
  1. Schwanke Engines
    Schwanke Engines
    '37-4D likes this.
  2. '37-4D
    '37-4D
    Something I've never done.
    Not very savvy in that department.....yet!!!
    The shop is going to do it for this time in order to insure proper function and warranty any issues if any.
    I'm learning....I guess it's a first step :cool::D
    Kustom Cline likes this.
  3. '37-4D
    '37-4D
    Finally on wheels
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Not the exact seated position as there still was a reinforcement bar behind me:
  4. '37-4D
    '37-4D
  5. Schwanke Engines
    Schwanke Engines
    '37-4D likes this.
  6. '37-4D
    '37-4D
  7. rolltideglin
    rolltideglin
    ......Have 3 x2 carbs & intake for sale[348]....400.00+ shipping...
    '37-4D likes this.
  8. that is one nice truck!
    '37-4D likes this.
  9. sloppy jalopies
    sloppy jalopies
    how much do you need ? I have a couple chunks of '35-''36 outback... memory says that is called a ... sill...
  10. '37-4D
    '37-4D
    Thanks rolltideglin, I already found one. See previous posts on this thread.
    Cheers
  11. JimmyD3234
    JimmyD3234
    from PA
    truck is looking K:cool::cool:L
    '37-4D likes this.
  12. '37-4D
    '37-4D
    Thanks JimmyD3234 :cool:
  13. earlymopar
    earlymopar
    Great looking truck. I'm curious if you have beefed up or plan to beef up the S10 T-5 to handle the torque of the 348?
    - EM
    '37-4D likes this.
  14. '37-4D
    '37-4D
    We removed the '37 Ford truck dash and inserted a '37 car dash instead.
    Then used the top of the old truck dash, reversed it and welded it where the front windshield header use to be. I thought that was a brilliant idea from skunkvictim (Binbrook Speed Shop in Canada). As the original header was quite damaged, this was a quick fix adding a touch of "cool"
  15. '37-4D
    '37-4D
    So far I'm using the S10 T-5 as is.
    I haven't approached that subject yet with the engine shop.
    I was told that the ratios balance out with the tire size being very different.
    I don't know how much truth there is to that statement.
  16. Schwanke Engines
    Schwanke Engines
    It should do just fine, much stronger than the old transmissions everyone used to use.
    Sent from my XT1585 using The H.A.M.B. mobile app
    brEad and '37-4D like this.
  17. '37-4D
    '37-4D
    That's what I was also told on the 348-409 forum.
  18. Schwanke Engines
    Schwanke Engines
    '37-4D and brEad like this.
  19. earlymopar
    earlymopar
    The reason I asked is that I just went through this issue myself. Of course, a lot depends on how your engine is built, how you intend to run it, vehicle weight and what gearing and tires you'll use. It would be a good idea to verify the torque capability of your specific T-5 and see how that relates to the torque of your engine. Beyond that, there are several T-5 sources that offer various improvements to enhance HP & torque capability.
    - EM
    '37-4D likes this.
  20. '37-4D
    '37-4D
    Please do share some of these sources. I won't put together something that I'll regret immediately after a few drives!!!
  21. earlymopar
    earlymopar
  22. flatheadpete
    flatheadpete
    from Burton, MI
    Pretty cool little truck. Gonna be fun with that W in there.
    '37-4D likes this.
  23. models916
    models916
    going to look cool.
    '37-4D likes this.
  24. '37-4D
    '37-4D
    earlymopar, thanks a bunch. Spoke to my motor guy and from the looks of it, with the weight of the car and the tires as well as the rear gear ratio we will be using, it won't be an issue. Now if I had slicks on it to drag, different story!! ;)
  25. '37-4D
    '37-4D
    Just got my intake back from a guy who does silver nitrate paint process and chrome pretty much anything. When done on smooth surface, you wouldn't know the difference. I've seen it used as an alternative to chroming. It is also heat resistant to 340 F
    And in this particular case the cross over p***age will be blocked, so I decided to go for it.
    Ground my intake down to smoothen a little.
    Here is an inspiration pic of an skunkvictim's Olds Rocket motor with the chrome and color look I'm going for:
  26. brEad
    brEad
    That intake manifold looks killer!
    '37-4D likes this.
  27. '37-4D
    '37-4D
    Thanks brEad
  28. '37-4D
    '37-4D
    Some more body work.
    On front and rear window and drip rail filler strip and some...
  29. '37-4D
    '37-4D
    A little progress delay as we are still waiting on the motor to finish the fire wall which will allow us to finish the interior floor and cone.
    WE should see it this week or next.
    Nobody said getting parts was easy... Lol
    Once the car drops to its lower stance due to the weight of the engine, we can add the bed skirt, finish the exhaust and get on with the pretty things I hope.
    Here are some more invisible work as I call it:
    Bed inner frame for woodwork. Thinking Jatoba!
    Tank location, gate install...
  30. Max Gearhead
    Max Gearhead
    from Wisconsin
