Technical 37 ford wide 5 brake drum removal
Discussion in 'Traditional Hot Rods' started by stowe, Dec 17, 2022.
  1. stowe
    stowe
    Hello
    I need to change a wheel cylinder and have to remove the drum. On 37 Ford I am looking for a puller large enough at big box stores as well a hobo freight and northern tool. Any suggestions on where to find one to buy or rent ?
    Thanks ,
    Chris
  2. Budget36
    Budget36
    Current thread on this regrading a ‘32. You’ll want the KR Wilson style of puller, it grabs the lip on the part of the drum behind the axle nut.
    PS. You won’t find it locally.
    Pocket Nick likes this.
  3. Budget36 likes this.
  4. Budget36
    Budget36
    ^^^^. Good deal, I can’t figure out how to link threads from my phone.
  5. Highlight and copy the url from the search bar when you're currently on the thread that you wish to share. Then jump to the thread and paste the url in the box where you type your comment. Should work since the mobile version looks just like the desktop version.
  6. birdman1
    birdman1
    Take a blacksmith hammer and hit the hub of the drum sharply, turn it 90* then tap it and so on around until it pops loose.i know the purists will come down hard on me, you just have to know how to run a hammer. Lol
    Belgian Belly likes this.
  7. stowe
    stowe
    I have struck out on locating anyone with the tool instock . May have to improvise .
  8. alchemy
    alchemy
    Too bad you don't show us where you are from, there may be someone around the corner who can bring theirs over.
    rusty valley and Moriarity like this.
  9. 51504bat
    51504bat
    From a prior post looks like he's in Florida or at least once was.
  10. stowe
    stowe
    Yes SW Florida .
  11. Glenn Ninow
    Glenn Ninow
    You need a vintage Plomb Tool Company hub puller - I found one on eBay a year ago for under $100 it looks like this - [​IMG] the little crescent shaped piece fits on the lip of the hub just below the nut. Good luck!
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    I have one of these. Works just great. the guy has sold hundreds of them with good feedback.
    what city are you near in SW Florida??
    https://www.ebay.com/itm/183765904026
    An example of same type in action.
  13. 51504bat
    51504bat
    Since when does the rear axle nut break loose with 1/2 of a turn with an adjustable wrench?
    oj, Ebbsspeed and vtx1800 like this.
  14. Mr48chev
    Used backwards at that. No way are you going to get one to come loose that easy either.
    The tool will work but you are going to be using a 24 inch breaker bar rather than a crescent wrench.
    That video reminded me of why I locked up all the Crescent wrenches in the high school autoshop the first week I was teaching.
    51504bat, WalkerMD and Ebbsspeed like this.
  15. brading
    brading
    If I were to do that I would that the washer off then use another nut with a plate welded on the end of it screw it on till bottoms out . Then when you apply pressure it is to the shaft and not the threads.
  16. Budget36
    Budget36
    Are you speaking of the “Jack one side up, give the other side a smack” method?
    What you have there is similar to what I did for my ‘32 Dodge rearend. But I screwed. Bolt into the nut, welded it up, then tightened down and wrapped it with a 5 lb sledge.
  17. fiftiescat
    fiftiescat
    from NY
    look up a company called "Vintage Precision". They make a modern puller that is worth every damn penny. I have one and it gets the job done every time.
  18. brading
    brading
    No I meant for the type of puller in post #12 and the KR type of puller etc.
  19. Boneyard51
    Boneyard51
    I think he screwed the nut off too much. I would have just loosen the nut , maybe one turn. Just my method!
    Bones
