Hot Rods 37 laSale - 50 olds transmission
Discussion in 'The Hokey Ass Message Board' started by Chopped Tudor, Jun 6, 2022.
  1. Chopped Tudor
    Chopped Tudor
    from DETROIT
    I have a chance to buy a empty 37 Lasalle trans case. I have a very nice 50 olds 3 speed, will the complete 50 guts fit into the 37 case?
  2. 42merc
    42merc
    Very common swap in days gone by.
    Do a search, it's been covered before
  3. RonaldR
    RonaldR
    Maybe Paul will chime in and give the info on what it takes.
  4. fabricator john
    fabricator john
    from venice fl.
    i believe its the other way around , correct me if im wrong but it was lasalle guts into a olds case to eliminate the lasalle long tailshaft , the lasalle shifter may work on the olds case as well ..
    fabricator john
    miss you dad
  5. Chopped Tudor
    Chopped Tudor
    from DETROIT
    Very common to use a 50 olds tail shaft on the lasalle boxes.
  6. Chev38
    Chev38
    The cluster gear shaft is larger on th '50 Olds. '37 case needs to be bored for the larger shaft.
    302GMC, Paul and Chopped Tudor like this.
  7. Paul
    Paul
    Editor
    Chev38 is correct.
    To swap all the later gears into the '37 case it will require some machine work.
    But, the easiest way is to start with a complete '37 transmission and swap just the clutch shaft, tail shaft and tail housing, no machine work necessary.
    Either way you will need more than just an empty '37 case to make the swap.
    Chopped Tudor and lumpy 63 like this.
  8. Paul
    Paul
    Editor
    I've only gone through a dozen or so LaSalle and Olds transmissions and only three of this specific conversion so am no expert.
    I took the easy route with this one,
    But have another with the case opened up for the later cluster if I ever get around to it.
    Edit:
    When I did this one it felt like I was taking two $800 transmissions to make one $1200 transmission..
  9. Tony, if you need any real info about what you want to do, contact " SHEP" (Mark Shepard ) a friend of mine from Connecticut. He is my age, and has done several Cadillac / Lasalle conversions. tell him that you got his info from me. 1-860-884-6833. that is his cell phone number which he uses in his shop from *9:00 AM until around 5:00 PM. Shep is a great person, a fantastic machinist, and will not steer you wrong. nick.
    Chopped Tudor, Paul and Budget36 like this.
