37 to 48 ford spindles
Discussion in 'The Hokey Ass Message Board' started by opu27, Nov 24, 2011.
  1. opu27
    opu27
    from ONYX,CALIF
    IF i had 2 drivers side spindles and cut off steering arms and used bolt on steering arms could i use drivers side for p*** side ? Are they the same except for steering arms ?
  2. lowsquire
    lowsquire
    from Austin, TX
    ha that one made me think!
    the answer is Yes. I think? **** now im not sure! They are symmetrical in a vertical plane so it must be yes. I think.
  3. Von Dago
    Von Dago
    from New Jersey
    Interesting question. The grease fittings will be facing the other way, but you probably figured that out already.
    Seems like it would work.
    I'd like to know the answer too.
  4. DICK SPADARO
    DICK SPADARO
    The spindles are symmetrical, after removing the arms the only distinction would be the index of the grease fittings as already posted.
  5. opu27
    opu27
    from ONYX,CALIF
    thank you Mr. Spadaro
