Technical 371 Olds
Discussion in 'Traditional Hot Rods' started by buick320a, Sep 2, 2020.
  1. buick320a
    buick320a
    from indiana
    Is the extended bell on a 57-60 371 a little different than the earlier 324
  2. Paul
    Paul
    Editor
    Some small differences, all machined surfaces, bolt holes, alignment pins are the same.
    There may be slight clearance issues requiring a little grinding internally on the 394 if using early flywheel and clutch.
    Most differences are "cosmetic" like the round windows went away with the 371,
    The 394 had cast buttresses added at the top of the bell..
    There are a few other slight differences..
  3. d2_willys
    d2_willys
    from Kansas
    Alignment pins are in the same place, however if the 324 was used with the single coupling hydramatic, the pins were on the block. The later blocks had the pins in the transmission. I know that this is true for 303 with hydramatic. (I mounted the older hydramatic to a 1960 371. The 371 had the dual coupling hydramatic, which had the pins on it.
