37'chevy frame vs 47-54
Discussion in 'The Hokey Ass Message Board' started by Sunnfjordingen, Dec 31, 2012.
  1. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Hello, I have a 37' Chevy (sedan delivery) that I plan to start a street rod build on soon and I am planning and looking at different parts to use and as far as I can see that the pickup frames looks very similar up to 54', is this the case?
    I have found a lot of parts for 47-54 trucks and I am wonder if some of it will fit the 37' frame, thinking about things like drop leaf-springs and disk brake-kits for original spindles. I also need some steering components. I'm using a 69 Nova rear axle.
    :confused:
  2. If you have a car-based sedan delivery, you want stuff made for the cars, the trucks have a different style of frame rail.
  3. Sunnfjordingen
    Sunnfjordingen
    from Norway
    I have the C-channel frame... :)
  4. thewishartkid
    thewishartkid
    I dont know about C-channel frame. As long as it is a sedan type frame.Unless you have a truck style Panel truck.
  5. Sunnfjordingen
    Sunnfjordingen
    from Norway
    If I'm not mistaken the pickup, delivery and Coupe(?) has the C-channel frame and the car models have the "hat-profile" frame, from it's shape if you see it from the end.
    Mine has the same as the pickup.:cool:
  6. Sunnfjordingen
    Sunnfjordingen
    from Norway
    I know the front axle is interchangeable, only the kingpin has some differences.
  7. mr.chevrolet
    mr.chevrolet
    if you have a C channel frame you probably have a panel delivery, based on the pick-up truck. so all pick-up parts will work. the sedan delivery is based on the p***enger car and all p***enger car suspension will work.
  8. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Great :) so how about the 47-54' pickup suspension parts then?
  9. spooler41
    spooler41
    Sunnfjorden, '37/38 Chev car frames had a top hat cross section. The truck frames were
    a"C" channel, 1/2# and larger.
    .....................Jack
  10. lawman
    lawman
    Speedway should have everything you need.
  11. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Yes I HAVE(!!!) the C-channel/pickup frame, the question was if I can use 47-54' pickup suspension parts?!
  12. Sunnfjordingen
    Sunnfjordingen
    from Norway
  13. lawman
    lawman
    Now your going !!! Good luck and keep us posted.
