37y project
Discussion in 'Off Topic Hot Rods & Customs' started by 37Y, May 24, 2024.
  1. 37Y
    37Y
    37y1.jpg 37y5.jpg 37y4.jpg 37y3.jpg 37y2.jpg 37y.jpg My new project. Ford 37y 2dr. Gibbon body (#2). Coilover 4link frt and coilover 4 link rear aftermarket frame. Pinto/Capri 20.l Ford 4cyl. Side draft 40dcoe Webers, intake to match, headers, Racer Walsh stage 2 cam. The interior looks like it has been pulled and adapted from a 1970's something Pinto/Capri donor car. Older Ron Francis wiring. I believe this was an early to mid 80"s build as I found one sticker on the back of the early digital dash.
    I really don't have much info to it's past life. I do know the guy I bought it from had it for 3yrs and that he got it from a guy that supposedly had it sitting in his garage for 27yrs.
    Anyway, here are some pics deciding to take it, then loading it up to go home.
    By the way, if anyone knows any thing about this ride let me know.
    Thanks.
  2. Bandit Billy
    Bandit Billy
    Kewl but you need to have it moved over to the Off Topic forum so it isn't deleted. I will ask @Moriarity to ***ist you. Oh, and welcome man! Look forward to seeing more on the car.
    chryslerfan55, SS327 and Moriarity like this.
  3. 37Y
    37Y
    Ok, thanks. I wasn't too sure where to start with this.
    chryslerfan55 and Bandit Billy like this.
  4. Bandit Billy
    Bandit Billy
    No worries. We just added the other forum and getting used to it. I'm glad it there for just this type of thing. We are all in this thing together. What are your plans for it? Any changes or leave it as is and drive the hell out of it?
  5. 37Y
    37Y
    Planning on driving it. My wife wanted a smaller little hot rod to drive, I wanted another hot rod project to keep busy and then drive together (dog included). Basically a cool little knock around car with some power and decent gas mileage.
    I have pulled the engine apart and called Racer Walsh....bought Crower rods (5.0), Wiseco pistons (.030), Racer Walsh stage 2 cam (285 adv. solid), followers, springs, retainers, gaskets..etc..
    Replaced the radiator and hoses.
    Went through the carbs. I'll sync them once running.
    Replaced rear coilovers with correct coilovers/springs (QA1) Did the same with the frt's.
    Once I get the engine back together and broke in, time for it's rough maiden to see what I got. Clean the thing up real good, then take it from there
  6. 37Y
    37Y
    Also installed the Holley reg. and braided lines/fittings. Set the pressure to 2.5#'s.
    edit, forgot I also remove the old Mallory mech distributor, cleaned it's gut's inside, reinstalled.
  7. So this 37y is a model of 1934 ford- maybe the smaller european version?
  8. Kerrynzl
    Kerrynzl
    The opposite ....
    The 33-34 Fords were modelled off the British Ford Y [32-37]
    Ron Funkhouser and 37Y like this.
  9. 37Y
    37Y
    That sounds about right as I understand it too.
  10. 37Y
    37Y
    From Wikipedia, the free encyclopedia
    Ford Model Y
    Overview
    Manufacturer
    Ford of Britain
    Ford SAF
    Ford Germany
    Ford España
    Production 1932–1937
    Body and ch***is
    Body style
    2-door saloon 4-door saloon
    2-door estate
    2-door van
    2-door pickup
    Powertrain
    Engine
    0.9 L Ford Sidevalve engine
    Dimensions
    Wheelbase
    90 in (2,286 mm)
    Length 141 in (3,581 mm)
    Width 55 in (1,397 mm)
    Height 64 in (1,626 mm)[1]
    Curb weight 1,540 lb (700 kg)
    Chronology
    Successor
    Ford 7Y
    Ford Model C Ten
    The Ford Model Y is an automobile that was produced by Ford Britain, Ford SAF and Ford Germany from 1932 to 1937. It was the first Ford automobile specifically designed for markets outside the United States, replacing the Model A in Europe.
    Ron Funkhouser likes this.
  11. 37Y
    37Y
    I do find it funny that the state it was registered in where I bought it called it an Anglia. The state I register it in calls it an Anglia too. Probably no column for model y in both state's books and they just picked "Anglia" and called it good.
