Hot Rods 38 chevy straight axle front spring direction
Discussion in 'The Hokey Ass Message Board' started by 6inarow, Jul 3, 2025.
  1. 6inarow
    6inarow
    Which eye goes to the front on a 38 chevy passenger straight axle front springs? I took it apart and forgot to take a picture
    dana barlow likes this.
  2. squirrel
    we can't see what clues you can see, so it's hard to say without having a 38 Chevy nearby.
  3. Rickybop
    Rickybop
    Found a picture for you.
    Looks like the eye that's rolled on top goes to the front.
    But find some more pictures to verify. Search original 1938 Chevrolet leaf spring front suspension.
  4. 6inarow
    6inarow
  5. twenty8
    twenty8
    Don't the two pics show it differently...???:confused:
    @Rickybop , I think your pic shows the '39-'46 1/2 and 3/4 ton truck setup.
    Kerrynzl likes this.
  6. squirrel
    winduptoy likes this.
  7. poco
    poco
    from oklahoma
    Yes shackles to the front.
  8. twenty8
    twenty8
    I am fairly sure this pic shows the passenger car setup. I will side with @squirrel on this one.
    6inarow likes this.
  9. twenty8
    twenty8
    I don't think this is correct for passenger vehicles. You might be thinking of the truck suspension....
    6inarow and squirrel like this.
  10. twenty8
    twenty8
    See at the bottom under "MASTER MODELS ONLY" (front suspension) where it says that the front springs have reversed front eyes. A reversed eye would be rolled downwards, so the rolled down end is the front.
  11. 6inarow
    6inarow
    Well I found a few interesting things. On the passenger car the rubber snubber on the frame that keeps the spring from bottoming out hits the top spring but the top spring is only half a spring. if that make sense. I have seen several pictures and they are different. some show the front of the spring with the eye rolled up and some show the eye rolled down. My manual says the pick up and the passenger cars are the same. so it seems to me there is no clear consensus. But @squirrel diagram looks like my rod now.
    Thank you everyone for commenting. I am finding there are not as many dropped axles and truly "old school" suspensions out there on Chevys out there as I thought.
    wixski and twenty8 like this.
  12. twenty8
    twenty8
    In 1937-1938 there was a difference between the front springs on Chevrolet passenger cars and 1/2 ton pickups.
    This (below) is the main leaf from a '37-'38 passenger car. Note the front eye is rolled fully downwards.
    This (below) is the 1/2 ton pickup front spring. One eye is rolled to be centered to the spring leaf, and I think it is the rear eye. The trucks had the shackles at the front........ I think...:confused:
    Rickybop and 6inarow like this.
  13. deathrowdave
    deathrowdave
    from NKy
    Exactly correct ! Car spring front roll goes pointing downward
    twenty8 likes this.
  14. Rickybop
    Rickybop
    Hey @6inarow
    Seems I gave you wrong info.
    Careful of me. :rolleyes:
    I believe @squirrel Jim got it right. He almost always does. And @twenty8 Steve was good enough to clarify it further.
    6inarow and twenty8 like this.
  15. 6inarow
    6inarow
    OK, so I check my springs and they are in backwards - I put the reversed eye in the back. What are the consequences of this? Should I turn them around?
  16. Affect caster
  17. 6inarow
    6inarow
    Yead I figured that out after a little research. Out they come.........
    swade41 and anthony myrick like this.
  18. swade41
    swade41
    from Buffalo,NY
    I had mopar trailblazer springs in the back of my 41 pickup in the early days. That spring was made the same way, I found if I mounted it one direction over the other it would raise or lower the rear. Also the roll down end didn't have as much travel when set in the solid mounted hangers versus the rolled up end.
    6inarow likes this.
  19. [QUOTE=" I am finding there are not as many dropped axles and truly "old school" suspensions out there on Chevys out there as I thought.[/QUOTE]
    The Chevy beam axle sits underneath the spring, so lowering requires a lot of thinking, sometimes too much work to get it all to work.
  20. 6inarow
    6inarow
    Yeah, I get that. But Im gonna do it anyhow. This is truly going to look like a rod that a young man would have done right after the war but with some modern concessions (that you wont really notice) for saftey. Almost like it will belong on the HAMB!
  21. Rickybop
    Rickybop
    Again, take my information with a grain of salt cuz it might be not exactly correct. Maybe way wrong LOL. So verify.
    I think you can use 1939 through 1954 spindles. And then the process, use the later better brakes. And they make dropped spindles for 1939 through 1954. Install a bushing for the pin in the later spindles to fit the smaller 1938 pin.
    6inarow likes this.
  22. 6inarow
    6inarow
    Hey @Rickybop thanks for the post. I switched the springs to the correct way. I got the dropped axle installed. Next this is get the rotors etc installed then on to the MC and plumbing. How cool are 6 lug discs going to be with the original wheels??? Heck by looking you wont even know there are discs.... HAMB friendly Thanks to @bob myers for all the help and encouragement. We have a cool ride going!
    swade41 and Rickybop like this.
