Projects 38 Ford brakes
Discussion in 'The Hokey Ass Message Board' started by Hupphaus, Oct 17, 2025.
  1. Hupphaus
    Hupphaus
    Rebuilding a 38 Ford 1 1/2 ton dually. Would like to do a brake conversion to disc brakes on front and back. Any suggestions on kits for the these bigger trucks? I’ve found them for the 1/2 tons. Appreciate any help.
  2. rusty valley
    rusty valley
    I doubt there is anything made for big trucks. Maybe have to put modern axles under it.
    Try calling Chucks Trucks, he would know
  3. 51504bat
    51504bat
    You might check over on the FTE. I seem to remember someone using mid '80's front brakes from a F250 on a early big Ford truck. But as usual I might be wrong. No clue as to the rear. Probably need to convert to a later rear end.
