Features 38 Ford - Chevy Power question
Discussion in 'Traditional Hot Rods' started by Dobrosailor, Feb 20, 2022.
  1. Some of us haven't bought into the must have "Ford in a Ford" mantra...FYI, that's a SBC block in my underway '38 project Ford. If "some ***embly is required" on your project '38, you might want to change out that Corvair front suspension and brakes for a dropped axle set-up. My understanding is the claim to fame for the Corvair front suspension is that it bolts in with 6 bolts...so it should also be easy to remove. Feel free to check out the build thread in my signature line. It too has a dropped axle set-up. 20210211_122751_resized.jpg
  2. Do what I did on Henrietta the '38 Ford pickup. Paint the small block Chevy the dark green color used on Ford flatheads. Put Ford emblems on the no-name valve covers. Make up a ****-and-bull story about the rare Ford experimental OHV engine.
    NashRodMan likes this.
  3. goldmountain
    goldmountain
    I don't understand the Ford into Ford thinking. Engine swaps are at the core of hot rodding. Even GM got into the act. I distinctly remember that my brother's Buick Regal had a 301 Pontiac engine in it.
  4. 31Apickup
    31Apickup
    It’s all just metal
    Artiki and Larry T like this.
  5. proartguy
    proartguy
    from Sparks, NV
    As far as the market I doubt that a Ford running gear swap will do much to enhance the value. Aside from the Corvair front end the GM stuff is pretty typical and fits well. If the o/p plans to only have it 3 to 5 years I would suggest finishing it up and enjoy it or sell it for a Ford powered ride you like better.
  6. Yep, I used to own an '86 Olds Cutl*** ... came from the factory with a 305 Chev in it.
  7. GMC trucks in the '50s used Pontiac V8s. Many larger Chevy trucks in the '50s used Buick nailheads.
