Is there a exterior door handle from another vehicle that would bolt right up to my 38 coe doors and give me door locks? I'd like to eliminate the keyhole on the p***enger side and have regular locking handle type locks if possible☺
To make them fit into the COE latches, you need to file off the edges of a short section of the square shaft. If you have a stock handle, you can use it as a template for the location.
Thanks, for pilin' on I remembered sumthin" special had to be done,thanks again figured help would show up...
