38 Ford Front Saga CONTINUED
Discussion in 'The Hokey Ass Message Board' started by Tuck, Sep 8, 2003.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Heres pics of my progress over the weekend
    First off I wana thank GREG [36threewindow] on the hamb for the suprise I got in the mail... He offered some machined bungs for the end of the bones... not only did he send that but the tie rod end, machined bolt and bracket for the chassis???? DUDE, I owe you BIG, thanks so very much!!!!!
    So I welded ongregs nicely machined bung and then ground it all up so you cant see his handy work... but its burned in DEEP and i polished out the weld heres a look see....
    PIC ONE
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I also worked on fileing down my welds on the tire slashers and polished this bone to 180... CLeaned up my spindles and droped the centers out of the finned drums by cutting the rivits.
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    splattered my spring so I can get it blasted and then im gonna tweak the tips of each spring w/something really SPECIAL, you'll have to wait and see [​IMG] I'm gonna use this spring in the back.
  4. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    took the backing plates apart in all its components and dropped that and the spring off to get sandblasted this week.
    A QUESTION?
    How much machineing is required to fit the 40 ford backing plates to the aluminum drums?
  5. plan9
    plan9
    dude tuck, that is lookin tight!!
  6. bobbleed
    bobbleed
    from Awesome
    Dude I don't think that spring is going to work. I think it's too wide. You need a spring that's made to go on top of the axle and some perches to mount it there.
    Call Posies, I think they make a "HollyWood Tuck" spring that will be perfect for you.
    Speedway will have perches.
    Looks nice though.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    were gonna use that spring in the BACK right?
  8. Kevin Lee
    Kevin Lee
    Super Moderator
    Can you effectively use '40 brakes with Buick drums at all? I thought you needed the bigger Lincoln style brakes. Hope I'm wrong here.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    the lincon and the ford are both 12" brakes... you cant use the f-100 b/c they are 11" brakes... the only difference on the backing plates is the offset.... the lincolns wont require the buick drums to be machined.
  10. bobbleed
    bobbleed
    from Awesome
    Yep, that spring on the back.
    Yeah, I have 40 brakes/ Buick drums on my roadster.
    The buick drums need to be machined where the edge of the backing plate hits them. The ford hubs need to be installed on the drum first and the backing plate installed on the spindle. Then the back edge of the drum needs to be relieved enough for it to go all the way onto the spindle without rubbing on the backing plate.
  11. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    cool, thanks bleed, thats what i figured when i mocked it all up. Rockys gonna send me the hubs were doing some horse tradeing, I understand the machineing on that end... looks like ill have to take a trip over to visit CAS muhaahhaha !!! should I bring the file paper and guide coat and trade off some work on the fibertub[tm]???
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    Lesson learned.
  13. Nixer
    Nixer
    Teh picture with the teh whole assembly on the ground looks wicked. The windcatchers (tm) on your bones look better than before. Is there a space on your axle in the middle? Looks good. also i got a new shirt...i will send you a pic of it..got a lot of attention at teh car show that i went to on sat.
    tok
  14. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    toke,
    theres no space, just a shadow...
    Dude abelugo sent me a couple vondrunk t's... they're funny as hell... the have a bottle w/ xxx's and wings on the back.
    i missed yer calls this weekend. Heres the rear fender abe sent me, its just laying on the tire so it looks funny but you get the idea....
    talk to ya later homie,
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Cool! Yes Tuck, Greg (36threewindow)is the greatest he gave me a set of these to weld into my support brackets. Thanks Greg!! It's so cool to belong to this board with people like this!
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    bttt and ROCKY I PM'd you look for the flashing envelope in the upper left hand corner,,,
    petejoe, that rocks! I try and pass it on as much as possible!!! thats what makes this board RULE!
    Tuck
