Hot Rods 38 Ford horn button removal??
Discussion in 'The Hokey Ass Message Board' started by jimcaf, Sep 26, 2018.
  1. jimcaf
    jimcaf
    from san diego
    I have a 38 Banjo wheel ,the shaft is cut off and its hollow ,cant figure it out ,,,thanks ahead
  2. alchemy
    alchemy
    Horn shaft must be caught down at the carnage. Should pull straight out. Was it torched and some slag is holding it?
  3. jimcaf
    jimcaf
    from san diego
    Thanks Alchemy ,,it was torched off ,I just ground the slag off and put a long punch through the shaft to the back side of the horn ****on and whacked it good with my ball peen hammer and still nothing gives
  4. pprather
    pprather
    Isn't it like other Ford's of that era? Remove the horn ****on by pushing it in and turn it left - counterclockwise.
    Sent from my LGL158VL using The H.A.M.B. mobile app
  5. jimcaf
    jimcaf
    from san diego
    Thanks guys..i just got it,,the while top was spinning after I soak it with liquid wrench the very center freed up and turned and it all made sense from there
