What sort of frame mods are needed when running a chevy 350/turbo 400 in a stock 38 frame? How about sources of parts (fenders, running boards, bed parts, etc.)? Lets see those 38/39 ford pickups. Here is mine, just picked it up on Sunday...
Looks like a good starting point. Check out Ch***is Engineering for info on the engine/trans swap. http://www.ch***isengineeringinc.com/page55.html Basically you need to take the centre out of the x-member to allow the trans to slide through and split the wishbone so that it clears the trans-pan. The ch***is on the 38 1/2 ton pickups are basically the same as the 35-40 P***enger frames, so there is a heap of information out on the internet and here on the HAMB. Here's a pic of my old pickup from about 10 years ago ...
