38 ford pu front spring
Discussion in 'The Hokey Ass Message Board' started by rustiepyles, Sep 25, 2013.
  1. rustiepyles
    rustiepyles
    Ok so I just started a 38 ford pu that Im bobbing. I got a 38 axle with wide 5 drums and wheels. I want to move the axle a few inches forward to center it under the x member and run a spring over axle as apposed to the stock 38 set up spring forward of the axle problem is I need a 33" spring to do this (properly anyway) But I cannot find a 33" spring anywhere. Anyone have any thoughts on this before I spend big bucks to a custom spring made.
  2. i think Posie's has a spring for that
  3. 42merc
    42merc
    Detroit Eaton Spring will make any leaf spring you desire. Call them with your wants.
  4. rustiepyles
    rustiepyles
    Looked at posies, couldn't find one.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Model A spring is about 31". HRP
  6. rustiepyles
    rustiepyles
    31" is 2" to short
  7. F&J
    F&J
    Posies does make the correct spring for "spring over" on a later axle like yours. I think it also comes in 2 versions; stock or reversed eyes
    Look under "front springs" 28 to 34 years, not the later 35 up listings
  8. take a look at Posie's part #'s 1009 , 1009S , 1009L and 1009H
  9. rustiepyles
    rustiepyles
    Bam! Got it, Thanks. Those are perfect.
