'38 PU grille designs?
Discussion in 'The Hokey Ass Message Board' started by sammamishsam, Feb 28, 2008.
  1. sammamishsam
    sammamishsam
    I started hanging the sheet metal back on the '38 last weekend. The grille is in decent shape but I'd like something cleaner. Anyone have pix of alternates? I was thinking of removing the vertical bars then replacing the horizontal bars with continuous pieces.
  2. glmarkie
    glmarkie
    I don't have any alternate pics but running just horizontal bars might look pretty cool. Good luck.
  3. earlymopar
    earlymopar
    IMO without the vertical bars to break-up the grill area (and only using horizontal bars) the grill is going to look much larger. They're already quite large and if I was going for something other than stock, I would look to make the grill appear smaller.
    - em
  4. 97flatrat
    97flatrat
    I have dozens and dozens of pictures of 38/39 grills but it isn't something you see modified very often. Here's the best I could do - these appear to be filled in although the second might just be a 39
    Personally, I like the 38 grill as is just fine!:D
  5. SimonSez
    SimonSez
    You may already know this, but the '39 grille has a single centre bar and is cleaner looking than the '38 grille right off the bat.
    Maybe try to find a pic of a '39 grille and photo-shop the centre bar out ?
  6. PollockzRodz
    PollockzRodz
    The grill on the 38 and 39s sorta makes the truck. I also think that down bars would look pretty damn good like glmarkie said If you went that way
  7. sammamishsam
    sammamishsam
    97flatrat Thanks for the pix. Like the looks of the white one. I have a spare grille that the farmer used as a bumper in the fields. I agree with the comments about the vertical bars making a difference in apparent size but I think I'll sacrifice the beat up grille in the name of experimentation. I'll be hard pressed to make it look any worse.
  8. harpo1313
    harpo1313
    from wareham,ma
    i think if you put the verticles close to each other it wouldnt make it look larger,gotta say though that red one looks sweet
