383 stroker question
Discussion in 'The Hokey Ass Message Board' started by bluejester, Aug 12, 2011.
  1. Martys 55
    Martys 55
    your buddy didn"t clearance the rod bolts and they are hitting the cam lobes. a buddy of mine bought a motor that someone else did had the same problem, # 7 for sure
  2. bluejester
    bluejester
    from ohio
    The block is ground for the rod caps but your saying to check the bolts to see if they are running into clearance issues. This motor was running about 4 years ago fine would this still maybe be an issue (rod bolts)
  3. bluejester
    bluejester
    from ohio
    These are the engine specs that I have:
    Keith Black flat top pistons
    1.65 trickflow roller rockers
    trickflow twisted wedge heads
    Edelbrock performer rpm dual plane intake
    SSI cam 510 lift 490 duration
    3800 TCI stall converter
    TCI streetfighter turbo 400 w/shift kit
    One pair of custom hedmann headers
    Holley 750 cfm dual feed carb
    My buddy says this dynoed out at 450 hp and 480 tq
  4. Larry T
    Larry T
    Sounds like way to nice of an engine to just crank it up and see what happens.
    Larry T
  5. bluejester
    bluejester
    from ohio
    Yeah that's why I want to take my time and make sure what the problem actually is. I also have a 54 crestline which is my next project but I'm keepin the engine stock 239 y block.
  6. Jack60
    Jack60
    from Maryland
    About two months ago, crank broke, #7&8 rods bent, pin on # 7 piston put a hole in the block, rear main cap broke and oil pump broke...............:rolleyes:
  7. bluejester
    bluejester
    from ohio
    Ouch that sucks
  8. n847
    n847
    I'd prolly tear it down these guys are right too much motor to chance it! Gotta protect that investment!
  9. brandon
    brandon
    Cheaper to buy gaskets than another motor...:D
  10. n847
    n847
  11. bluejester
    bluejester
    from ohio
    Good news I pulled the heads off and there was some rust at the top of cylinder number 8. I made a mixture of tranny fluid and kerosene and was able to get it clean everything is rotating fine now. However I do have a new question/s about the cylinder head mating surface, I should use a block as long as the head to surface the deck right about 200-250 grit? Also use the same grit and process on the aluminum heads? I have never resurfaced an aluminum head for this. Please let me knoe any info will be helpful.
  12. bluejester
    bluejester
    from ohio
    Also what do splayed end cap bolts look like or do all 2 bolts have them?
