39-40 ford coupe bodies
Discussion in 'The Hokey Ass Message Board' started by 47chevycoupe, Nov 10, 2012.
  1. 47chevycoupe
    47chevycoupe
    from Finland
    What are the differences in 1939 and 40 coupe bodies?
    1) windshield
    2) door vent windows
    3) dash
    4) 39 std cowl and 39 deluxe & all 40 cowls
    From my searching this is all of the differences I could find. Is that it??
  2. arkiehotrods
    arkiehotrods
    That's all the differences I know about!
  3. Old Tin and New Tin
    Old Tin and New Tin
    The inside of the lower outer edge of door window opening on a 39 is smooth all the way across the bottom. The 40 has a small indentation in the bottom inside edge at the rear of the wing window where the front of the roll up window stainless bar goes up and down.
    There is also a small difference in the curvature of the bottom of the front fender in the area below the hole where the bumper braces go through and the center grille area.
    Obvious exterior trim differences.
  4. 39 Ford
    39 Ford
    You guys missed the windshield wiper and radio antennas. 39' wipers are on top of the windshield. Antenna's are in a different position, 39's fold back onto the windshield and 40's can be lowered by sliding them down..
    The firewalls are different at the toe board also.
  5. BJR
    BJR
    Windshield wipers?
  6. Flatheadguy
    Flatheadguy
    Yes, "windshield wipers".
    '39 are above the windshield, '40 below in cowl.
    And, the wheel bolt circles are also brake drums are quite different.
  7. rpu28
    rpu28
    from Austin
    '39 was the last year with crank-out windshields and cowl vents. Lots of little things, like the various Ford and V8 badges, trunk handle, etc.
  8. 39 Ford
    39 Ford
    40's has cowl vents actually the same part as 39's.
    This thread is going adrift as the question was 39-40 bodies, not all the differences in the entire car.
  9. 39 Ford
    39 Ford
    The 40 used the same cowl vent as a 39.
    This thread has gone adrift as the question was only about bodies.
  10. fleet-master
    fleet-master
    not really gone adrift...as the mounting points for the windshield are totally different for instance...so the structure may be different.
    I've recently been modifying a pair of Drake 40 doors to fit a 39 coupe. Swapped over the entire inner frame section as the mounting for the window mech was all different , also the method of attaching the inner garnish was changed that year...had to change that too...
    and so it goes on...lots of differences!! :eek::D
  11. 47chevycoupe
    47chevycoupe
    from Finland
    Thanks for the info. I have bought a rust free 40 4-door sedan. Have talked to Carpenter about their coupe body. Getting it delivered to the house increases the price by 15%. Not sure if I want to spend that much money. I have been thinking about trying to find a 39-40 rusty coupe and use my floor and doors on it.
  12. joel
    joel
    Anything is possible, but if you have to pay for the body work, I'd buy the Carpenter body, and sell the 4dr to someone who wants it.
  13. Southfork
    Southfork
    In what ways is a 39 std coupe cowl different from a 40 coupe cowl? Just the wiper location? Or is there something else that is materially different?
  14. 48FordFanatic
    48FordFanatic
    from Maine
    Wiper location
    Headlights
  15. 48FordFanatic
    48FordFanatic
    from Maine
    Sorry ...you said body ....so disregard headlights
  16. scott 351 wins
    scott 351 wins
    I just bought a 39 coupe body and is in rough shape, what is the diference in the cowl area? can i use 40 standard front clip instead of finding a 39?
  17. cryobug
    cryobug
    You can use a Forty front end if your 39 is a Deluxe
  18. 1great40
    1great40
    from Walpole MA
    Geez, no one mentioned that the 39 body is also a year older!!!!!! :)
  19. scott 351 wins
    scott 351 wins
    So is mine a standard or Deluxe? Wow didnt expect the pic to be so BIG,sorry.
  20. scott 351 wins
    scott 351 wins
    how do I convert it over to a 39 deluxe/40 standard front clip then?
  21. joel
    joel
    The sheetmetal where the dash mounts and the windshield opening itself . If you use a '39 tip out windshield, you're ok. If you need to see, I can send some pics. PM me and I can get them tommorrow.
  22. DD COOPMAN
    DD COOPMAN
    Another easy way to tell a '39 Standard is the radiator "steady rod" brackets at top of firewall. '39 DeLuxe did not have those. DD
  23. 47chevycoupe
    47chevycoupe
    from Finland
    This is what I would like to find. Cut at windshield and use my cowl.
  24. scott 351 wins
    scott 351 wins
    i found it on ebay, won it for 600 bux, it has no floors at all. will be a major project for sure.
  25. BabyLincolnsDad
    BabyLincolnsDad
    Anyone know if the 38 or 39 truck hood and sides fit the 38 or 39 coupe? I am looking to put the truck nose on my coupe body and wondering how much modification it will take.
