39 Brake/clutch assembly
Discussion in 'The Hokey Ass Message Board' started by HK 40, Nov 20, 2024.
  1. HK 40
    HK 40
    How to remove from frame ?
  2. slowforty
    slowforty
    Should just unbolt. Remove the floor board and see what is there. Use a good light.
  3. 37 caddy
    37 caddy
    from PEI Canada
    39 Ford? im looking for one if you are wanting to sell it?
  4. slowforty
    slowforty
    I have a nice 40 Tudor Deluxe available
  5. joel
    joel
    I believe the pedal mount is the same as '40; it uses 4 5/16 bolts IIRC the top rear is thresded into the bracket through the frame and the other 3 are bolts and nuts. There must be some difference as the '40 is marked O1A. I think the same bracket is used through '48. There is a snap ring on either end of the cultch/brake shaft and it's probably easier to remove the pedal arms before removing the bracket. The pedal shaft is pressed in the bracket, but is replaceable.
  6. slowforty
    slowforty
    The linkage for the clutch equalizer shaft may be different
  7. Andy
    Andy
    39 does not use an equalizer shaft. The mount is very different between 39 and 40.
    I much prefer the 40 up style as they do not require the steady rods.
    I put a side shift trans in my 32 and used the later clutch set up. I had to make a special offset pedal mount but it all went in with no frame mods. I did work over the pedals
    The 40-48 stuff is way cheaper and more available. Someone gave me my pedals!
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the main board. Antiquated is for non car related 65 and older stuff and big trucks
    Tim likes this.
