Projects '39 chevy brakes
Discussion in 'The Hokey Ass Message Board' started by Burner, Oct 24, 2013.
  1. Burner
    Burner
    Hi All, I've been trying to post this thread but it doesn't seem to go through.
    I've decided to put a hydro boost brake booster on my '39, but i need to ask the experts a question. I picked up a hydro boost ***embly at my local junkyard for $60 with the pedal and mc. It fits great under the floor if I turn it upside-down. I need to know if the hydro boost will work that way. The booster came out of a chevy van and it has 3 ports in it. The routing is as follows; 1) from the steering gearbox 2) to the steering pump 3) to the ps tank. My question is, does port 3 need to be up to keep the internals full of fluid or is it just a pressure relief drain line?
    Thanks
    Paul
  2. Burner
    Burner
    There we go, I wasn't using a prefix.
  3. dinokruzordinance
    dinokruzordinance
    Not to hijack ur thread but theres a parts car here local if you need sheet metal. Looks like ur good from ur avator. Just a heads up if u need it
  4. themoose
    themoose
  5. K204DR
    K204DR
    from Chatt TN
    doesn't matter how its oriented. they will work upside down just fine.
  6. Burner
    Burner
