Technical 39 Chevy overheat
Discussion in 'Traditional Hot Rods' started by toms63, Sep 19, 2024.
  1. toms63
    toms63
    I have a stock 216 that has an overheating problem. I back flushed the radiator and did clean out a lot of dirt/rust. The thermostat opens at 170 degree when tested. The car will sit idling and remains at 180 degrees, this is indicated on the gauge and an infrared thermometer.
    I can drive at 15-20 MPH without overheating heating. When accelerated to 40-45 MPH it immediately overheads and quickly goes to 212 degrees. I will try a total engine flush, and a test for bad head gasket.
    I am looking for any ideas or like experience.
    Thanks, Tom
    Tow Truck Tom likes this.
  2. jaracer
    jaracer
    I'd say you need to have the radiator rodded. You have sufficient capacity to cool the engine when there is little load but not enough when you put a load on it. I had a 47 Ford that was good to 40/45 mph but would overheat if you pushed it any faster. It's very indicative of a plugged core. It may be hard to find an old fashioned radiator shop that will pull a tank and rod a radiator.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    ^ Wondering if the impeller in the water pump is rotted away and no longer able to move coolant as it should...?
  4. I will second @jaracer comment. If you can't find a radiator shop, I have had good luck removing the radiator, turn it upside down and flush it. I have also laid it flat with two short hoses on it and filled it with a 50% solution of white vinegar and let it sit overnight, then back flush.
    Tow Truck Tom and squirrel like this.
  5. Joe H
    Joe H
    I have read where a lot of the 216/235 engines have a bad rap for filling the lower part of the blocks with trash. Pull the core plugs and dig around. A high pressure power washer does wonders when you need clean block p***ages.
  6. 302GMC
    302GMC
    from Idaho
    Had a pump impeller come loose once on a "rebuilt" pump. Be worth a look ....
  7. distributorguy
    distributorguy
    from MN
    Retarded timing and lean fuel mixture also cause heat. Make sure the vacuum advance isn't slowly leaking. It should be able to hold advance indefinitely. Engine timing should reach 32-36 degrees at full centrifugal advance without the vac unit hooked up. If its not advancing the engine WILL overheat!
    Use your infrared thermometer to verify you're getting about a 40 degree temp drop from the stat to the bottom radiator hose. That indicates the radiator is good. A pressurized upper hose with the radiator cap in place should indicate both circulation and a higher boiling point than 212. A new cap may be in order if there is no pressure building.
    leon bee likes this.
  8. 302GMC
    302GMC
    from Idaho
    Chevrolet didn't pressurize cooling until 1948 - it's open to atmosphere.
  9. toms63
    toms63
    Thanks for all the replies. I have also heard that removing the freeze plugs and cleaning out is a good idea. I will start at the top and try all remedies.
  10. leon bee
    leon bee
    I did the vinegar on a running engine and radiator. Also did the *****-hose filter trick. Immediately learned to take a nut driver for the hose clamps on any little test drive. Filter clogs up quick!
  11. I’ve flushed with CLR
    and with cascade dish washing tablets.
  12. Agree. It IS the radiator.
  13. toms63
    toms63
    Distributorguy,
    Engine running at idle, temp. gauge reads 180, thermostat housing reads 162, bottom radiator hose reads 136. As mentioned earlier this is not a pressurized system. 160 degree thermostat.
  14. Don't just try the radiator clean out first and try it or you will be doing it again very soon as all that **** that's blocking it ''came from the engine''. JW
