39 colume switch replacement
Discussion in 'The Hokey Ass Message Board' started by sedan_dad, Jan 19, 2004.
  1. sedan_dad
    sedan_dad
    Anyone know how to do it?The key and tumbler are wore out and I've ordered new ones .Is there much to it?
  2. rodrelic
    rodrelic
    On the back side is a hole, my 37 had a pin in it that stake's the cylinder in place. Drilled it out, destroing the cylinder that was junk anyway. If I remember right, the key had to be in the lock to put it in or out and turned a certian way. Shoild be easy if enough room is there to get a drill in straight. Someone must have a pic of the drop dis***embled, if not I could take some.
  3. sedan_dad
    sedan_dad
    That would be great.Thanks dude.
  4. Crestliner
    Crestliner
    I really can't remember for sure. There is either a small bolt in the rear or a spring loaded pin to push. Key will have to be in on position and pull. If its a pin you will have to hold the pin in while pulling.
  5. Bruce Lancaster
    Bruce Lancaster
    Do it like rodrelic says, but try to drill on center of the pin and go slow--you only need to drill about 1/4" or so through soft steel, when you see br*** shavings you have reached the cylinder. It just slides out once pin is killed--no tricks with key. Key code will be on side of old cylinder, likely a new key will makeitworkok. Replace pin with set screw covered with a dab of putty or heavy paint.
  6. Bruce Lancaster
    Bruce Lancaster
  7. sedan_dad
    sedan_dad
    Great site and great pics.I can't thank you enuff.
    SD
