'39 Deluxe/'40 Ford Similarities & Differences (technical)
Discussion in 'The Hokey Ass Message Board' started by phartman, Jan 20, 2010.
  1. duste01
    duste01
  2. merc-o-madness
    merc-o-madness
    is it possible to fit a 39 deluxe grill in a 40 ford? They look soooo much better would like to use one
  3. mj40's
    mj40's
    When I bought my 40 pickup it had a car fender on the driver’s side and a pickup on the p***enger. Both fit the grill and hood well. The noticeable difference was where it bolted to the cowl and running boards. It had a noticeable gap down the cowl area and no bolts into the cowl. That flange on pickups is flat as compared to cars that have holes and the flange flares out a bit. Which is another way to tell if you have pickup fenders. They bolt to the running boards and a small bracket at the top of the fender/hood line. I got the correct fender with the buy and changed it out later
  4. J Man
    J Man
    from Angola, IN
    What are the details on these are far as the ch***is, wheel/tire and drivetrain?
  5. The '39 on the left is now Ryan's. He just wrote a piece on it.
  6. hotcoupe
    hotcoupe
    `39 deluxe grill = $$$$$!
  7. 39 All Ford
    39 All Ford
    from Benton AR
    I want to say that another small difference between 1939s and 1940s is that 1940 door strikers are spring loaded with the mounting bolts being on a vertical line in the strikers, and 1939 strikers being bolted in place on a horizontal line and not spring loaded.
    Pretty much a meaningless difference, but since I did not see it posed here... :D the same latch ***embly seems to be used on each.
  8. 296 V8
    296 V8
    from Nor~Cal
    Iv had early and late 40 coupe doors side by side and the late door had a small indentation were the trim on the gl*** at the windwing would go up and down with the door gl***.
    The early door didn’t, leading me to believe early 40 doors are very close or the same as 39.
  9. OHEKK
    OHEKK
    Here's my '39 coupe:
    It is For Sale if anybody is interested
