39 ford brakes?
Discussion in 'The Hokey Ass Message Board' started by Tim, Feb 18, 2004.
  1. Tim
    Tim
    from KCMO
    the front brakes off a 39/40 4 door Ford. are they worth using on a highboy?
  2. Tim
    Tim
    from KCMO
  3. redbeard
    redbeard
    do you mean no one.
    I was confused at first by the body comment.
    anyhow yes.
    if they are 40's they should have the regular 5x5 1/2
    bolt pattern
    if they are the 39's they would have the wide five pattern.
    still usable but not as many wheel options, just the 36-39
    ford wheels, I like them but most people don't run them.
    if they are 39' you can swap on later drums for the 5x5 1/2
    pattern.
    good luck
  4. Mr 42
    Mr 42
    from Sweden
    Yes why not?
    Its more or less the same as type the 46 brakes.
    Nowadays everyone goes to the F1/Lincoln type that is a better construction.
    But the old type has worked for decades, And in a light Highboy they would work ok.
  5. Anderson
    Anderson
    I'll be using juice '40 brakes with wide 5 '39 drums on my mod. They oughta be good enough. I think mine will be lighter than a highboy though, so I'm not worried about poor stopping capabilities.
