Hot Rods 39 Ford brakes
Discussion in 'The Hokey Ass Message Board' started by willumbilt, Jun 10, 2015.
  1. willumbilt
    willumbilt
    Hey guys- Can any one offer up tips on getting brake drums off on 39 Ford juice system that's been sitting for a long time? Project is 35 Ford p/u that was converted who knows when. The drums move, but wow are they stiff! Moving the eccentric adjusters on the backing plate seems to provide very little clearance for anything to move. Been trying to squirt WD-40 in behind rear edge of drum, but limited results. Don't want to damage anything, and I'm afraid to apply heat at this point. Thanks in advance for any experienced advice!
  2. steel rebel
    steel rebel
    Are we talking about front or back? Back require a puller. They are a keyed taper fit. Fronts should slide right off.
  3. Revrev
    Revrev
  4. Texas Webb
    Texas Webb
    As Revrev said ^^^^^ good puller.Got mine last year.
  5. Any chance there is a set of safety hubs holding the drum on (if they are rear)? You can identify safety hubs by two of the 4 bolts attaching the backing plate having been replaced with studs and nuts. You still haven't told us if you are working on the front or rear drums, it would narrow down the problem considerably.
    Charlie Stephens
  6. Rocky
    Rocky
    Classified Editor
    The poster has had 3 months to get his problem fixed since he posted this...I'll bet he found a solution by now.
