COE 39 ford c.o.e. build
Discussion in 'Off Topic Hot Rods & Customs' started by pex, Oct 6, 2010.
  1. pex
    pex
    from alberta
    On the dash pics you can see the front windshields are in. the dash is painted with dupli-color machinery grey(3.80 can) and i didn't cheap out and used a whole can. i'll get it outside for some better pics soon. I'm very happy with this build so far.
  2. mad-cad
    mad-cad
  3. Donnda
    Donnda
    Nothing less than "FANTASTIC"
  4. fabmancoe
    fabmancoe
  5. pex
    pex
    from alberta
    had this afternoon to work on the truck. got the throttle hooked up, all the gl*** is in, fan for rad hooked up, seat bolted down. working on shifter and e-brake tonight. thanks for the positive comments. if the weather improves i should get it outside for some pics soon.
  6. b-bop
    b-bop
    Hey Pex, where are the updates. I am expecting you to drive up in my driveway any day now for a frosty beverage and a shakedown cruise :D
  7. Donnda
    Donnda
    I think Pex is goofing off and not paying attention to COE business !!!!!!!!!!
  8. pex
    pex
    from alberta
    well i've been busy and no one mentioned frosty beverages. i think i'm going to have to stick a flat deck on it so i can get some miles on it while i'm working on the art deco style deck. i get my insurance tomorrow.
  9. fordheadEd
    fordheadEd
    got me jealous as all getout, looks great, nice work so far. Getting into mine heavy now
  10. pex
    pex
    from alberta
    Again the powers that be are testing me. i had the engine running and then all hell broke lose. first the trans was no good so i changed that.(tues) then the alt decided to fry it self so i unhooked that.(last night) then i went for a short drive and i was tickeled until it quit and i put it back in the shop and after having breakfast with the guys today i proceded to try to figure out WTF was happening.well i just came in after a day of trying to figure out whats going on. as far as i can tell, the camshaft is pouched and i screwed up a valve or two by overadjusting the valves, even the fuel pump isn't pumping so after changing it i decided that its posible the cam broke. now if this isn't enough the rad sprung a leak when it got up to 180 degrees. tomorrow i will shoot a handfull of gofers to apease the gods and start over. if i didn't have a gl*** half full outlook on life i'd be a basketcase. i have a 350 out of my old work truck,if that dosn't work i'll sell a kidney and buy a crate engine. update in a few days.
  11. Donnda
    Donnda
    .Now Greg, you know that just shooting the gofers is not enough to please the gods. You must cook up a couple of deep dish hot gofer pies and eat them for the best luck.
    Sorry to hear of all your woes but in my case if I don't do it at least 3 times it isn't done. Hang in there and just do it one step at a time and keep a positive outlook it WILL come together
    -Donn-
  12. pex
    pex
    from alberta
    The problem was that the patriot heads i spent my hard earned money on are junk and after running for a short period the intake gasket let go above the runners. the sheep loving hillbillys who manufacture these fail to mention anywhere you need oversize gaskets if you run victor jr or preformer intakes. I wasted a weekend and alot of money.
  13. pex
    pex
    from alberta
    so i took the patriot heads back to my supplier and went with rebuilt OEM heads. i would never feel confident running the aluminum ones after the grief they caused. i'm still not sure if i damaged the cam and lifters but will find out this weekend. i know i said i'd post some new pics soon. i hoping sunday. i also pulled the engine from my old work truck and cleaned it up just in case. i will not be defeated.
  14. pex
    pex
    from alberta
    Well after a few bumps and not having a rad i drove the truck off the lift and turned it around outside. seems to run just fine with all the gauges and electrics working. time to get after sanding and build some kind of deck for the bonneville trip. [​IMG] [​IMG]
  15. Donnda
    Donnda
    Grttin' excited.
  16. pex
    pex
    from alberta
    changed out the rad and have been getting the bugs worked out. rides really good even without the weight of the deck. i've got a few days set aside so i'm hoping to get lots of little things done. donn- i'm thinking of comming to your place wed the 10th of aug then meeting up with the guys fri the 12th. looking forward to our visit and getting some work done on your c.o.e. greg
  17. Donnda
    Donnda
    Greg, Looking forward to your visit. You are going to drive the COE down right? If you need a place to gather the "guys" I have 20 acres here and anyone is welcome.
    -Donn-
  18. pex
    pex
    from alberta
    yes donn- the c.o.e. will be coming with. had it up to 70mph today and i can't believe how much sandblasting sand is still showing up, i must have forgot to remove the beach. LOL might have to change out the high pressure oil pump, its hard to seal up the engine with that kind of oil pressure(50-70psi) yikes
  19. Hi Guys
    Yes I know I have been very quiet lately but I have been flat out like a lizard drinking, (old Aussie saying) for busy
    What I would like to see though is bigger pics of Pex's Fords COE, can't see much detail in little pics.
    Please !!!
    Yes I have been working on my 41 Ford COE, every day !!
    Seeya
    Bill
  20. wetskier2000
    wetskier2000
    from NH
    Great COE! Thanks for posing it's progress. I just brought home a 1941 that won't move nearly as fast as yours! What did you do for a windshield? Looks like no center bar. thanks!
    Rick
  21. pex
    pex
    from alberta
    Bill-i'm in the middle of sanding but i'll take some bigger pictures soon. what do you want to see? i'll get some help as i don't know how to make them bigger.
    rick- the windshields are glued in using butyl tape and urethane with a v-
    **** in the center with a bead of clear silicone to seal it up.
  22. pex
    pex
    from alberta
  23. wetskier2000
    wetskier2000
    from NH
    Pex, that is VERY Cool! You lose the flip out ability, right? I really like the idea of being able to flip out the windshield, but I also am going for highway driveability. I suspect your setup will be MUCH quieter than 2 pieces that can flip.
    Rick
  24. Hi Pex
    Have found your FlickR site sand have download over 60 photo's so far,:)
    A picture tells a thousand words or something like that.
    thank you
    Seeya
    Bill
  25. Hi Pex
    I stopped at 93 pics, Thank you, very informative
    Seeya
    Bill
  26. pex
    pex
    from alberta
    so i spent around 40hrs on the quickie deck( nothing is quick anymore ). also have been sanding and i hate sanding. i'm finished to 80 grit and its getting smoooooooooooth!!!!!!!!! hope to get into another coat of primer tomorrow or monday. i mixed up a color today for the primer. i'll say its a one of kind and it should pop. stay tuned LOL
  27. pex
    pex
    from alberta
    ran out of materials today. i'm also out of steam-money etc. so i'll putz from now on. [​IMG]
  28. pex
    pex
    from alberta
    a couple more . [​IMG] [​IMG] [​IMG]
  29. b-bop
    b-bop
    Well look at you, poster boy for Texaco. The color combo matches, red neck and lilly white legs........ kidding man, looks great. Just checked out your flicker album. Quickie deck looks great
  30. wetskier2000
    wetskier2000
    from NH
    Awesome!!! Thanks for the thread, the pics and especially the motivation! I only hope mine can come out 1/2 as nice.
