Hot Rods 39 Ford cowl mechanism
Discussion in 'The Hokey Ass Message Board' started by AngleGrinder, Dec 5, 2020.
Tags:
  1. AngleGrinder
    AngleGrinder
    Need more space under the dash. The 39 Ford cowl lever and mechanism use up a lot of space. Does anyone have any suggestions on modifying for a tighter smaller fit? Is there an after market kit? Thanks
  2. lothiandon1940
    lothiandon1940
    ......They make electric ones. It's kind of a street rod thing.:rolleyes:
  3. HOTRODPRIMER
    HOTRODPRIMER
    When I installed a heat & air unit in my 1940 Ford sedan I unscrewed the handle and made a piece of piece of 3/4" angle iron and bolted it to the face of the mechanism, I was able to move the handle closer to the steering column approximately 8". HRP
  4. AngleGrinder
    AngleGrinder
    Thank you for that. My 39 Ford looks the part so I'll probably fab something... don't know what yet. cheers
  5. AngleGrinder
    AngleGrinder
    Thanks, I'll do something similar, My AC is my cowl vent (and living in the far north). cheers
  6. AngleGrinder
    AngleGrinder
    Thank you for your suggestions. I cut the cowl vent handle and bent / welded a very old box end wrench to fit under a radio I'm installing.
