39 Ford Guys, Help Please. Banjo Wheel.
Discussion in 'The Hokey Ass Message Board' started by Rckt98, Feb 22, 2007.
  1. Rckt98
    Rckt98
    I need to get at the light switch on a 39 Ford banjo steering wheel. What's the trick? I can't work out how the horn ****on comes out. I have tried holding it in and turning it but that isn't happening.Someone must have pulled one of these apart.
    Thanks.
  2. Andy
    Andy
    There is a wire bale that holds the light switch and wiring harness on at the bottom of the steering box. Flip it off and remove the wiring thing. There is a little forked thing on the end of the horn rod and a spring. Push the forked thing up and remove a little horse shoe clip. The horn ****on and rod will come out now.
  3. Harrison
    Harrison
    Under that horn buton is a rod running all the way down the column to the switch which is actually down at the steering box. You'll have to unhook the rod down at the steering box.
    JH
  4. Harrison
    Harrison
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    You may or may not be able to completely extract the horn rod depending on the exact model of car - I know the pickups at least have a heck of a time w/o dropping the steering box!
  6. Rckt98
    Rckt98
    Thanks guys, that gives me something to play with tomorrow.
  7. Another tip. Be extremely careful not to bend the rod. If it is not going to slide out, follow Flat Ernies' advice and drop the box.
  8. 39 Ford
    39 Ford
    Once you unhook the rod it will pull up, it is very long and will hir the headliner before it comes free, you may need to drop the column,be carefull.
