Technical 39 ford ignition key
Discussion in 'Traditional Hot Rods' started by twostickmutt, Jun 5, 2016.
  1. twostickmutt
    twostickmutt
    any tricks for getting the key out of the switch on a '39 ford. the key turns fine and even locks the steering wheel like it should but i can't get it out of the switch. i've wd 40'd it and jiggled the key while turning the wheel back and forth some but just can't get it to come out. thanks for any help.
  2. I'd mega WD it and keep wiggling. Probably got a pin hung up inside.
    BrandonB likes this.
  3. Alternative....
    $22 from Howell's sheet metal
    LOU WELLS likes this.
  4. Dak Rat
    Dak Rat
    from NoDak
    Usually means the lock cylinder or key or both are wore out. Thoes old br*** keys get pretty rounded out after years of use.
  5. birdman1
    birdman1
    i have the same problem with my 1939 Ford coupe, so I turned the switch9screwdriver) on and left it. The toggle switch does the electrics so all is good.
  6. 1pickup
    1pickup
    My '39 Standard didn't come with a key, so we found one (50's maybe?) & shoved it in there. It works (sort-of). Like birdman1 says, the toggle works fine. No one under 60 would know how to start it anyway.
    Ravenwood likes this.
  7. Ravenwood
    Ravenwood
    from Texas
    [QUOTE="1pickup, post: No one under 60 would know how to start it anyway.[/QUOTE]
    Thanks! Best laugh I had today!
  8. twostickmutt
    twostickmutt
    thanks for the replies. and yes no one under 60 would know how to start it is perfect ! hahaha
