39 Ford spindles, F1 brakes and Buick Finned drums
Discussion in 'The Hokey Ass Message Board' started by Benjamin, Jul 2, 2007.
  1. Benjamin
    Benjamin
    Anyone ever run this combo? Any tips? I know I have to trim the spindles at the top and change bearings and races. I was going to just run the buick drums on my 39 brakes but got some f1 brakes today.:D
  2. Flat Ernie
    Flat Ernie
    Tech Editor
  3. MEDDLER1
    MEDDLER1
    if you use the 40 backing plates you dont have to grind the spindles,i have seen where a litlle grinding is done to the lip of the backing plate on the outer inside edge,even after machining the inside of the buick drum,this was with 40 hubs i am planning to do the same thing using the f1 hubs iam hoping they will sit out a hair further but im not counting onit.as far as i know the f1 hubs work great you just have to turn the backs down on a lathe and chamfer the inner bearing.so you will just have to get the 12"backing plates.hope this helps.
