39 Ford Trans question
Discussion in 'The Hokey Ass Message Board' started by scotts52, Jan 18, 2012.
  1. scotts52
    scotts52
    Ok I tried a search, but sometimes you gotta put in the right words to get the right answers. What I want to know, is what makes the 39 Ford trans so coveted and also, was it really only in the 1939 model year? Direct me to more information if you know the right search.
    Thanks
  2. Hitchhiker
    Hitchhiker
  3. Pintojoe80
    Pintojoe80
    Thanks for the link, I am new to these older transmisions having worked with the four speed top loaders for a long time. Good info
  4. scotts52
    scotts52
    Thanks Hitchhiker.
    After reading that article, It would appear that I may be able to swap the later gear set into a 37 case. Is that correct? If so, that would make the 37 case as valued as the 39's?
  5. chopt top kid
    chopt top kid
    Yes, the '39 and later ge****ts all fit in the series 78 gearcase. Henry started to use the 78 series case in 1937 and used it all the way up through the F1 pickup. The p***. cars switched to the sideshift case in '40. There are two ge****ts available, the car ge****t and the truck ge****t (extra low first gear). The '39 ****** was the only year that Ford offered the improved ge****t with the p***enger car ratio's and the top shifter, that's why everyone wants one...
  6. George/Maine
    George/Maine
    In 39 they went to a 3" fork thats the difference.
    They can be found in trucks with floor shifts to about 52.
    gears from 39 48 cars and to 53 trucks can be used in early cases.
  7. tommy
    tommy
    The 39 box became the most sought after back when you could go to a junk yard and pick one up for 25 bucks. Last year for the floor shift and first year for the better syncronizers. You could pull it out and bolt it right in. Just R&R. My cousin used one in his 46 coupe behind a nailhead. He told me in the 60s that there were no more 39 boxes left in the junk yards of SE Pa.:D So now we ***emble our own.
    Today the year of the box is not such a big deal but you will need the right shifter fork. As others have said if you blow a gear today, other year gear set can be swapped in but back then you just s****ped the box and got another one so you looked for a 39 box.
