Hot Rods 39 Ford Vs T5
Discussion in 'The Hokey Ass Message Board' started by krylon32, Jun 13, 2021.
  1. krylon32
    krylon32
    from Nebraska
    I know I've made a lot of money selling T5 conversion kits and transmissions but for 25+ years there's been a nice 39 trans with open drive conversion sitting in my storage shed. I also have an early 93 world cl*** T5. I have only had one car with a 39 box and that was 50 years ago and it always jumped out of 2nd gear. I have just had a nice FH built and this winter I'm starting on my retirement 32 roadster. I'm thinking about sending the 39 box to VanPelt for a freshening up and putting it behind the FH in the roadster which flies in the face of everything I've done for the past 25 years. I'm just wondering if I will regret my choice?
    loudbang, F-ONE and kidcampbell71 like this.
  2. birdman1
    birdman1
    I was reluctant to install a t5 in my 37 coupe with a 430 Lincoln. I had installed one in my 65 mustang boss 302 Shelby clone. I really like the way they shut and with the 4.11 gears, the 5th gear was welcome.i think you will like it.
  3. oldiron 440
    oldiron 440
    The difference in shifting alone would decide it for me let alone the additional gears.
  4. alchemy
    alchemy
    I agree. The '39 box it is!
    Driving a flathead with an original Ford trans is kinda a zen thing. You need to know the "rules", and usually follow them. It gives you a connection to real hot rodding, not modern hot rodding.
    Sure there are less gears to get you up to top speed, but once you are there the fun is the same. I bet you can choose the perfect ge****t for the quickchange to cruise at 70 MPH.
    hfh, Bugguts, stillrunners and 2 others like this.
  5. AngleDrive
    AngleDrive
    from Florida
    My answer would be No!
    kidcampbell71 likes this.
  6. oldiron 440
    oldiron 440
    Now if you're building a car with only original cl***ic parts then go with the ford transmission, if not go with the t5.
  7. Mr48chev
    I'm going to say it all depends on the driving plans for the car. I'd say that a lot of the feedback from your adapter comes from guys who rack up highway miles on their rods. The guys with the early boxes for the most part may not do as many long road trips.
    The overdrive lets you run a 3.7 or 4.11 rear gear and still be up around 3.0 final drive or under for the big long roads. With the three speed it is either run rear gears for poke around town or run gears for serious highway cruising with a bit of tricky clutch work around town.
  8. 2935ford
    2935ford
    I've had the old top loader 3 speed and a T5. They are both good but if a traditional build......gotta be the 39 box.
    Done right, it won't pop out of any gear.
  9. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    So what if it doesn’t pop out of gear. It was designed for machines with lesser horsepower. A decently strong flathead can put the cluster gear in shambles. Yes, I have had a “heavy foot” for years and way back there in the 70’s when the “only “ adapter available was the Offenhauser to Chevy 3 spd or 4 spd labeled as 5272a,I purchased one and ran a Muncie close ratio 4 spd and a nine inch ford knowing my “stronger” flatmototors could not and would compromise my ability to run my flat motors hard..Ran a Muncie 4 spd for 25 years after destroying all the available weaker 39 style boxes from the local wrecking yard. I know I will hear from the traditional “believers” that the 39 is o.k. But I tend to disagree. My 39 cabriolet (street driven daily in s.Texas) has run 80 in the 1/8 mile and performed flawlessly time after time. I vote NO on the weaker 39 box. 400F5D49-CB53-4731-A264-1C358A514141.jpeg 2DA571F3-1E9B-4286-B981-3553B61D56DB.jpeg
    loudbang, KiWinUS, Hamtown Al and 3 others like this.
  10. Ice man
    Ice man
    I had both in my 29, with a warm B block. Loved the T5.
  11. I would do the T5 no questions asked. When I owned the Rocky33 that is the one thing that made that truck so fun to drive.
    loudbang and kidcampbell71 like this.
  12. alchemy
    alchemy
    Gonna take my flathead powered sedan with its '39 box on a five hour (one way) road trip to Back to the Fifties next weekend. I've already done it over a dozen times.
    F-ONE and stillrunners like this.
  13. 5 hours? Thats a good reason for the T5! Isn't that a 3 hour trip in most cars?
  14. alchemy
    alchemy
    Cruise about 70 at 2600 RPM. Gotta have some leg stretching breaks along the way. Still has the s**** pedal, and no cruise control.
  15. AHotRod
    AHotRod
    The answer is: The T-5 for the Win !
    loudbang, kidcampbell71 and Tman like this.
  16. birdman1
    birdman1
    Surprised some pansy- *** hasn't recommend a aod! LoL
  17. denis4x4
    denis4x4
    from Colorado
    I have one of each behind my hot bangers. The T-5 is the answer. BS on the “zen” of the ‘39. Mine has synchronized Zephyr gears.
  18. redo32
    redo32
    Set your ch***is up with a crossmember for each ******. Put the '39 in for old times sake, if you decide you don't like it, you're all set to change it.
  19. HOTRODPRIMER
    HOTRODPRIMER
    I've had a 39 transmission behind a flathead in my old black 4 door sedan, I loved it driving around town or on the interstate,but when I drove the car to North Carolina or Tennessee it was inadequate,
    I currently have a 5 speed in the wagon and it is the perfect transmission for town ,country or mountains.
    I had a top loader 4 speed in my old 3 window and it had the old school vibe, I still have another 4 speed and a flathead waiting for a future project. HRP
  20. Pete1
    Pete1
    from Wa.
    If you use the 39, wait till you can find a set of 25 tooth gears. They are much harder to break and being closer ratio will be a lot more fun to drive. Even with no synchro on first, you can still downshift at 60 with 4.11's if need be.
    If you use the T5, put the #212 gear set in it. You will enjoy it more behind the flathead due to the closer ratios.
    Oh, and if you use the 39, put the standard mods in the shift cover and it will shift as fast as a Lenco.
  21. stillrunners
    stillrunners
    from dallas
    Funny.....maybe ask over on the Ford Barn with those guys running a 39 box behind their bangers - and how many smiles per miles they get ! Here - you always likely to get the non but happy not traditional reply.
    F-ONE likes this.
  22. 1935ply
    1935ply
    from peyton,co
    The tower sticking up thru the floor and a swan neck shifter is way cool in a roadster, with the stock park brake handle. I run the 39 style box behind a 50 merc. Also run a quick change with 3.48 final. It runs down the freeway at 75. The small front tires, potholes and ruts are more of a problem than no o.d.
    F-ONE likes this.
  23. manyolcars
    manyolcars
    I have driven cars from the 30s, 40s and 50s ONLY for 52 years. No modern cars. I broke 39 transmissions and they had been rebuilt and driven carefully. Go ahead with the 39 if your car is a toy that is rarely driven. If it will be used as a driver, the modern transmission changes the car from a putt putt to a pleasure to drive. I have driven my avatar to 4 states since I installed the overdrive transmission. I use a Model A shift lever
  24. Pete1
    Pete1
    from Wa.
    As a side note here, any piece of machinery can be broken if abused. It is just knowing where the breaking point is.
    I won the Northwest Hot Rod Road Racing Championship in 1954 running a 300 hp flathead into a 25 tooth 39 transmission. That was a 6 race season. Did it on one transmission and one engine. Used first gear 4 times each lap with downshift at 60 mph.
    At the drags the next day I won my cl*** at 116.58 in 11.34 sec. using second and high. The car was a 2300+ lb. 32 coupe.
    ClarkH, warbird1, williebill and 7 others like this.
  25. F-ONE
    F-ONE
    from Alabama
    The 39 box...
    It is what it is and what it is ain't bad.
    I think you would enjoy it. I had one in the F1 (the 1950 truck version). It was my favorite thing about the truck.
    Of course it was worn. It had been through at least one flathead and 2 302s. 2nd gear was an absolute blast behind a hopped up 302. That truck would freaking fly.
    Like I said, it was worn. It would not hold second in a coast. Under power or pulling it did fine.
    Personally I loved it, it was fun.
    Since you have/have had T 5 cars....been there done that, I think it would be nice for you to run a 39 again.
    If that unit is nice, I don't know if I would send it off. I would be tempted to try it if it looked good inside.
    Your results may vary.
    I had fun with mine and it was wore slap out.
    As long as you don't purposely try to tear it up, It should provide years of service.
  26. hotrodA
    hotrodA
    Not to derail your thread, but have you considered a T-170 from a Ford pickup? 3 speed + OD.
    I have one for my 40 flathead coupe, but it’s still sitting on the floor. :rolleyes:
    F-1 box in it works fine.
    loudbang and stillrunners like this.
  27. Hamtown Al
    Hamtown Al
    I love the 5 speeds behind flatheads and 4 bangers. I even loved the one I put behind my 291 Desoto hemi!
    You can so much more reep the fun of a flathead with the the added gear options.
    Just my opinion.
    I'm certain you can find an adaptor.;):D
  28. stillrunners
    stillrunners
    from dallas
    Could I ask what type of Q/C are you running ? And the gear set number in the rear - top gear number and bottom gear number ?
  29. junkman8888
    junkman8888
    My answer is neither. Find a '49-51 Mercury overdrive transmission, install the overdrive guts in your toploader box and then you will have the best of both worlds; the oldschool toploader vibe plus overdrive when you need it.
  30. 1935ply
    1935ply
    from peyton,co
    Running an original Halibrand V8 center in a '34 rear. Using 4:11 ring and pinion # 4 gear set, 22 on top, 26 on bottom.
