Getting close to mounting some fenders on the 39 Poncho, so today's questions- Did these use fender welting? My shop manual doesn't mention it. If so, I see some universal welting on line pretty cheap.
I used the cheap vinyl/rubber welting on my 39 chevy. It cleans up the gap between the fender and body ...it looks right.
Haven't put welting on my '39 Chev yet as I wanted to do it after paint. But with my Wimbledon White color I wanted something close to match, and only thing I saw was custom made welting covered in vinyl s***ched over round material. I kept looking, and found a company less than an hour from me that had welting formed in a bunch of colors that's a VW parts place. They had the perfect color and a 20 ft. roll was only $22. Haven't pulled or loosened my fenders yet to install it, as I'm always working alone, and need a 2nd person to ensure I don't mess up my painted fenders!
I have found the easiest way to install welting is to loosen the fender. Then see where the bolts that hold the fender on are, and mark them on tape on the outside of the fender. Lay the welting over the fender and cut a "V" in the flap of the welt where the bolt is. Push the welt into the gap with the "V" straddling the bolt, and move on to the next bolt. You may need to use some masking tape to hold the welt into the gap until the fender it tightened back up.
Hey brother. Can you do me a favor? If you pull your front fenders, can you shoot a pic of the lower cowl, between he firewall and the door? I picked up a repair piece for a 39 Chevy and its different. I was told, and heard, and read, that the Poncho Series 25 body was made by Chevy and identical to the Chevy coupe. Hmmm... Maybe you even have an old pic already? Thanx
Yep, this is the way to do it. I did it on my 40 chev. this way, easy and when its installed right and pulled snug, looks really good (straight). Just FYI, the black stuff looks great on just about anything.
Fender welting; I brought a '31 phaeton that had chrome fender welting which distracted from the fender striping.Had a local uphostery (sp) shop do the welting, color matching the body paint color, made for a better look.. dyno Dave
I wont be pulling my front fenders to do that tiny piece. And might not even do welting on the front at all, as it is such a small piece. I did find some old pictures, but nothing that's a good side view, but maybe they'll help?
Thank you sir. It does look different than mine. Odd because, supposedly, the 39 Poncho series 25 was a “Chevy body” with Pontiac designing their own fenders, hood, frame , etc…. The rear tail pan I bought was a 39 Chevy and it fit perfectly.
I know the fenders are different, but I also figured the mounting method with captured nuts would be the same on both Pontiac and Chevy. Figured the pattern might be different with the slightly different shape though.
