Technical 39 Pontiac ignition help needed
Discussion in 'The Hokey Ass Message Board' started by fyrffytr1, Apr 17, 2022.
  1. fyrffytr1
    fyrffytr1
    I am trying to get my 39 Pontiac series 28 4dr sedan ready to take to the swap meet in about two weeks and have run into a major roadblock for me. It might be a minor glitch for Y'all.
    I cannot get fire to the coil or spark plugs. I bought a new 6 volt coil, points and condenser. 6 volt battery is fully charged. I have the hot wire from the ignition switch to the + side of the coil and the - side wire goes to the distributor. Points gap is set to .016
    With key on I have 6+ volts on the + and - side of the coil. I have 6+ volts all the way to the points contact on the distributor side but I don't get a spark across the points when cranking the motor.
    I checked the other side of the points to ground and get 0 volts whether the points are open or closed.
    I drove this car a year ago.
    So what do I need to check next?
  2. Pontmerc
    Pontmerc
    from Finland
    Clean the points with fine sandpaper or file and wipe with alcohol soaked rag.
    fyrffytr1 likes this.
  3. Make sure the distributor shaft is turning, and then check the rotor ****on.
  4. jaracer
    jaracer
    Okay, you have 6 volts on the + & - side with the points open. With the points closed you should have 6 volts on the + side and 0 volts on the - side. From what you posted, it seems like the 6 volts on the + side goes away when the points close; is that right? If so, you have too much resistance in the wire going to the coil + side.
    If that's not the case can you give me voltmeter reading at coil + & - with the points open and the points closed? With that information I can point you in a direction to further troubleshoot your problem.
    fyrffytr1 and harpo1313 like this.
  5. fyrffytr1
    fyrffytr1
    OK. I went out to the car to check voltage. I took the distributor cap off and had my wife sit in it and depress the foot starter. Lo and behold the points fired! So I put the cap back on and hooked up my spark plug tester and it fired! I sprayed a little starting fluid in it and it cranked for just a second. Then I hooked up the electric fuel pump and tried it again. I think the carb is bad because the engine flooded out and I didn't even hit the gas pedal.
    But, at least the spark issue resolved itself.
    Bob Lowry likes this.
  6. Gofannon
    Gofannon
    Drain the tank and put fresh gas in it.
  7. fyrffytr1
    fyrffytr1
    No tank in it. Running out of a fresh non ethanol 5 gallon can. I have never done anything to the carb and I think that is where my problem lies.
    Gofannon likes this.
  8. G-son
    G-son
    from Sweden
    I hate when that happens. What fixes itself can unfix itself at any time, and not knowing what the cause was it may be hard to get it running again the next time it happens.
    fyrffytr1 and firstinsteele like this.
  9. fyrffytr1
    fyrffytr1
    Just an update to tell you the car decided to start yesterday. I helped it a little by putting a 12 volt battery and coil in it. But, I need to replace or rebuild the carburetor. Gas spewed out of it when I engaged the electric fuel pump and no amount of friendly persuasion with a small hammer would stop the flow.
