'39 toploader help--L.A.
Discussion in 'The Hokey Ass Message Board' started by OLLIN, Jun 23, 2007.
  1. OLLIN
    OLLIN
    I did a search already but..
    anyone know any places to get parts or a rebuild kit for a '39 trans?
    One of the gears (3rd gear?) has a bunch of broken teeth, but it looks to be all there and shifts fine. I saw from some other posts that there is a few variations, which one is mine?
    thanks for any help..
  2. Montechris
    Montechris
  3. abe lugo
    abe lugo
  4. Andy
    Andy
    I personally would not put much money in that. The case is fine but the gears all would need replacing to upgrade to the better shifting "39" style. Then you would need the later shift fork. I might have some gears for that one if you want to mess with it. What is busted? The cluster gear?
  5. 39 Ford
    39 Ford
    Try Joblot Automotive on the RIGHT coast in N.Y. Sorry I do not have thier #
  6. There is a Place in Glendale CA, called Trans-matic, that deals with 1930's-1970's transmission parts.
    Or call Crabtree Automatics, in Burbank, this guy Larry is great and does know his Toploaders and automatics.
    Sorry, I don't have anu phone #'s with me.
  7. flatford39
    flatford39
    Is there a number 78 on the case??? If so you can replace all those gears with ones from a 46 48 trans that had better synchros. The column shift 46 48 can be picked up pretty reasonably still.
  8. Mart
    Mart
    Not sure of the exact year, but the first and reverse are straight cut, so it's 36-ish. later were helical cut, as was the splines on the mainshaft. The gear you're pointing to is 2nd gear. There isn't a "3rd gear" as such, 3rd is straight through. If the box was earlier, the shifter tower would be sloping back.
    Mart
  9. weemark
    weemark
    from scotland
    im with the others, its not a 39 trans, looks more like a 35/36. have a look at the cast number on the rear of the casing underneath the two larger holes and you will be able to figure out what it is.
    the later ge****ts can be used in these cases, you just need to grind away a little of the casing to let the later ge****t fit into them, other than that they arent really different to the 39 casing. obviously the selector forks are different as well
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    Most of the major early Ford vendors carry bearings, thrust washers, small parts, etc. Gears are tougher - try joblot in NY & eBay, of course.
    If your mainshaft (output shaft) is no good, I'll take it! Need just the back half of one for a little science experiment I'm doing...
  11. See if Joe Mac is still rebuilding. He lives in Corona but is quite old.
  12. 50Fraud
    50Fraud
    Look up Alan Mest -- I think his address is in Gardena. He deals in early Ford parts and has a huge stash of early V8 mechanical bits of all kinds.
  13. HHRdave
    HHRdave
    from So Cal
  14. OLLIN
    OLLIN
    Awesome guys! thanks for all the help. I wire-wheeled all the **** off the back of the casing and it does say "78-7???-N"
    so is it really worth finding the 46-48 gears and shfter forks and upgrading..or should i find the '39 gears and forks...or should I just find the '36 gear that I need and try to run it that way, or are the '36 ******'s even worth it?
    I am running a pretty much stock for now 8BA flathead with (2) 94's.
  15. flatford39
    flatford39
    78 cases will take the later gears. They go in EXACTLY like the old ones come out. Keep notes or even better in this digital age take a few pics. The shifter fork you are looking for will have a casting number that starts with 81------ Appears to me that you are about a third of the way there.
    Good Luck and keep us posted.
  16. Flat Ernie
    Flat Ernie
    Tech Editor
    If you can be choosy, find a ge****t with a 16T input & 28T cluster - slightly better ratios than the other common ge****t (15T/29T)...
  17. OLLIN
    OLLIN
  18. OLLIN
    OLLIN
  19. Montechris
    Montechris
    The Shifter Fork has a part number of 91A the shifter housing with the double detent is 81A-7222
  20. Montechris
    Montechris
    Start Reading this will get you started.
    http://www.vanpeltsales.com/FH_web/flathead_transID_3speed.htm
    The gears you're looking at on ebay will drop right into your 78 box, the shifter forks you have will not work. I'm not sure if you can put the larger shifter fork(91A) in the older style housing or if you need to upgrade the the entire shifter housing. Plan to pay at least another hundred for the 91A shifter fork.
  21. OLLIN
    OLLIN
    there is a 91-A shifter fork that I am watching also.. if I win the gears I will try and get that too.
  22. OLLIN
    OLLIN
    awesome. I won permission to buy that ge****t!
    thanks guys for all the links and info.
  23. Mercmad
    Mercmad
    from Brisvegas
    I dunno ,but that trans looks like it has been under water,is that rust on the gears??.it would be a total waste of time ****in' with it if that is the case. It looks to be a '36 gear set a****st that brown stuff.
    Actually,apart from Zephyr Clusters the '36 was the better set to drive with,if a little 'whiney 'in first.theres was hardly any synchro so you can shift pretty Quickly from 1st to 2nd...without using the clutch.Just keep your foot in it, then once you learn the right sounding revs,just pull it straight into second. it takes practice ,so do it often enough ( might involve a few trans changes:eek:) and you'll wow the kids with your expertise at the bang shift.
  24. OLLIN
    OLLIN
    no, it spins fine except for the missing teeth. It probably just looks red because of the old ****** fluid or something.. It will be nice once i bead blast it and clean it up
    according to that link it should be a 37-50 case. probably 37 or '38 since it has the older style gears
  25. Flatheaded
    Flatheaded
    from Nordakoda
    I just rebuilt mine last week. Talk to Mac Van Pelt. He has all the parts and knowhow. Very helpful person. Go to his web site - www.flatheadv8.com Lot's of good stuff there. Buy his book on Toploaders, it's well worth the $$$$$ Good luck, Flatheaded
