'39 Transmission help!!
Discussion in 'The Hokey Ass Message Board' started by jghelm, Nov 22, 2009.
  1. jghelm
    jghelm
    from St. Cloud
    I'm looking for some help in what is needed to mount my '39 ford top loader to my '32 k member. I found one plate that bolts to the k member but doesn't have a way to mount to the transmission. Any help is appreciated, pictures would be great!
  2. Rem
    Rem
    Sounds like you have either the cast bearing retainer (#7085) or the rubber moulded rear mount (B-5089-B) and also need the other. There is also a flat plate, and the four T-bolts.
    This page on Mac's should should mount that bolts to the K-member:
    http://www.parts123.com/parts123/yb.dll?parta~partsort~A2
    The pic shows an exploded view of the parts (#5089 shown is the '33-'34, not '32 one).
  3. tommy
    tommy
    The sheet metal mount and rubber isolator is available from most early Ford houses. I don't know if someone has started to make the cast iron inner part that actually bolts to the trans.
