Projects 390 Cadillac engine
Discussion in 'The Hokey Ass Message Board' started by bogart62, Jul 23, 2025.
  1. bogart62
    bogart62
    Guys:
    Does the redesigned 1963 Cadillac 390 with dizzy in the front and narrower block size make for an easier swap into a 38 ford coupe?
    I have leads on 2 engines. A 1962 and a ‘63. Available of aftermarket parts can also be a decision maker. Thanks to all. Kent
  2. Dan Hay
    Dan Hay
    You'll just have to get the tape measure out and start figuring it out. Usually in early Fords, flatheads and small block chevys are about the only engines you can use without cutting into the firewall.
    I'm guessing it won't fit without cutting into the firewall, but that's just a guess.
    There's not a strong aftermarket with those engines. There was back in the day, so all those parts are really expensive now. Building a hot rod caddy is $$$$$. There's a whole thread on 390 Cadillacs here somewhere.
    https://www.jalopyjournal.com/forum/threads/lets-talk-cadillac-331s-365-and-390s.1015067/page-22
    chryslerfan55 and chevyfordman like this.
  3. warbird1
    warbird1
    I didn't have to cut anything when I put the '62 390 in my '40...
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, and I didn't have to cut anything to put a 331 cad in my 40. Those 63 390's are kinda orphans. there isn't much for aftermarket, not to mention they are ugly...
  5. bogart62
    bogart62
    I’m leaning toward the 1962 390. That dizzy up front is kinda off for me. Thanks
    warbird1, chryslerfan55 and Moriarity like this.
  6. Dan Hay
    Dan Hay
    He’s got a 38, and they are a little narrower at the front of the engine compartment than a 39 deluxe, 40.
    winduptoy and chryslerfan55 like this.
  7. I gave one of those away a couple years ago.
    The 390 that is
  8. An ugly engine?? How can that BE?
    Ben
    jet996 likes this.
  9. 42merc
    42merc
    To stuff a 365 or 390 into my '40 the firewall was not a problem, but the front of the oil pan sump was moved rearward 2 1/4" to clear the drag link.
    winduptoy, firstinsteele and alanp561 like this.
  10. ckh
    ckh
    If it were me, I would go with the '62. However, there are some HAMB members that like the '63 and swear it makes plenty power and torque totally stock with no need of after market intakes etc. As for
    the dimensions, I'll have to leave that to others as I don't know. My engine is a '55 331 and I'm looking
    for a pair of '59 thru '62 390 heads for it close enough that I can drive and look at them in person before
    buying.
    warbird1 likes this.
  11. saltracer219
    saltracer219
    Go with the 62, they have the same traditional look as the early Cads and they fit better in those cars. You might have to slightly trim the right Xmember to clear the oil filter but other than that they fit just fine.
    winduptoy likes this.
  12. bogart62
    bogart62
    Hope to look at the ‘62 390 this weekend. Thanks for the input
  13. warbird1
    warbird1
    Stock oil filter ***y. cleared well on mine, but was right in the path of the exhaust pipe, so went with a remote filter...
  14. Beanscoot
    Beanscoot
    Are you planning to use a manual transmission or automatic?
    If automatic, consider the 1964 429 as it's very similar to the '63 390 externally, but has a bunch more power and was available with a Turbo Hydramatic 400.
    I owned both a 1964 and '63 Cadillac many years ago and the '64 was a far better motor, and the TH400 a far better transmission than the earlier one.
    skooch likes this.
  15. Zottel
    Zottel
    365...yuck...
    390 ok
    429 all day long
  16. bangngears
    bangngears
    from ofallon mo
    To answer your original question. NO. And distributors upfront are ugly as....
    saltracer219, warbird1 and Moriarity like this.
