Technical 390fe
Discussion in 'The Hokey Ass Message Board' started by jhuebner, Sep 19, 2015.
  1. jhuebner
    jhuebner
    20150805_205321.jpg Rebuilt my 390fe for my 65 T Bird, installed CompCam K33 kit with lifters, springs, timing chain/gear, also installed new valves break in went well drove around the block 6 times every 2 trips pulled in the drive way to check for leaks everything was good drove up the block 1/2 mile and bam lifters sounded loose pulled valve covers cylinder 2 had a bent push rod and a broken lifter, pulled the intake, heads to further investigate couple of the other lifters have some nicks im guessing from the pieces of the broken lifter was able to get a few pieces out with a magnet, what would cause the damage
  2. 56don
    56don
    As has been written about on here often, did you use the proper break in oil that contains zinc and the other additives required for our older camshafts? Did you check the clearances of the lifters into their bores when ***embling to make sure they move freely?
    Are you using the stock Ford non adjustable rocker arm ***embiles?
  3. finn
    finn
    Dirty valve guides. A valve seized in the guide and bent the pushrod, allowing excessive lash.. the lifter is now in free flight and self destruction mode.
    Another possibility is that the lash was incorrect on ***embly.
    Any sign of piston to valve contact?
  4. jhuebner
    jhuebner
    No valve to piston contact, thats good........I used the cam break in lube that was with the kit also added some Lucas breakin additive to the oil.......seems like the valve hung up and caused the problem,will check later on the movement of the valves....looks like im starting all over again
  5. jhuebner
    jhuebner
    Forgot to mention im using the stock rockers.
  6. ClayMart
    ClayMart
    What's the carburetor in your picture? It looks like a customized, chrome plated Thermoquad. :confused: Just when you think you've seen everything... :rolleyes:
  7. FrozenMerc
    FrozenMerc
    That may be the Ford God's getting back at you for using that carb. It is a Ford FE, Put a Holley on it for Christ's sake. I agree with Finn, most likely a stuck valve. Check your valve guide clearance. Remember, as the guides warm up, the ID gets smaller, not larger. Metal expands uniformly in all directions, which means internal holes get smaller as the metal expands, and the valve stem gets larger.
    Good Luck.
    ClayMart likes this.
  8. BLACKNRED
    BLACKNRED
    Cam walk
    original cam may have had a thrust washer, new cam has thrust washer cast in.
    ***embling new cam with original thrust washer pulls cam out of the hole a bit and will kill the cam all all lifters.
  9. sunbeam
    sunbeam
    Do you have a pre 1963 motor late cams won't work.
  10. SicSpeed
    SicSpeed
    from Idaho
    I'd also guess guide clearance. I had that problem with a race engine yrs ago. Took the head porter 3 tries to get it right.
  11. jhuebner
    jhuebner
    StreetE="ClayMart, post: 11169764, member: 41881"]What's the carburetor in your picture? It looks like a customized, chrome plated Thermoquad. :confused: Just when you think you've seen everything... :rolleyes:[/QUOTE]
    Street Demon made by Holley, nothing custom
  12. jhuebner
    jhuebner
    Original 65 motor
  13. jhuebner
    jhuebner
    Interesting will check, followed procedures step by step and watched a rebuild series on youtube by aroosterrepairservice, I
  14. jhuebner
    jhuebner
    Im sure I destroyed the cam as well, will check into the thrust washer area when I pull the cam, sure ****s, living here in Germany makes it twice as hard and $$$$$$
  15. BLACKNRED
    BLACKNRED
    I did a budget build on a 1963 1/2 Galaxie 500XL, 352 25 years ago. put a new cam, lifters, new bearings hone and re-ring.
    Took the car on a 1200 Km round trip, just got home and the engine was rattling like crazy.
    Di-section found all bearings fritzed, cam had chips on the lobes and all lifters had chunks missing off them.
    fault caused by me not picking up the difference between the original and after market cam, never made that mistake again, built another 6 since then all went strong.
  16. jhuebner
    jhuebner
    Did the same new bearings, hone there was no ridge at the top of cylinder walls just shiny walls, re-ring the kit I used was complete with matching lifters, springs and timing set, just pulled the cam out its wasted as well as bearings not sure about the crank bearings will have to pull the engine anyway looking into the block while cam and lifters still installed I could see that less than half the lifter has contact with the cam lobe, with the original cam next to the compcam they are the same length, will post some pics
  17. jhuebner
    jhuebner
    Blacknred.....you called it I had the spacer between the cam and gear its not needed with a metal gear, just looked in the shop manual its called a spacer at first you threw me off calling it a thrustwasher I was thinking of the thrust plate all I can say is blank blank blank damn im pissed, lesson learned costly one
  18. FrozenMerc
    FrozenMerc
    Glad to hear you found the problem. Don't forget that the frost plug in the back of the block that goes in the cam bore goes in "backwards" from all other frost plugs. Putting it in wrong can lead to a similar problem with the cam walking out of place.
    This is correct.
  19. jhuebner
    jhuebner
    Sometimes you learn the hard way, will start the rebuild soon, got to sell a Chevy 6.0l Vortec I have in the garage to get some funds.
  20. Plootz
    Plootz
    This was a common problem I used to run into when I was a Ford parts person. Later timing gears had the spacer built into the timing gear. We would always have to caution and explain to the customer that the spacer was not to be used or you would have bad results.
    Too bad you had to learn that this way.
    Bill
  21. wheeldog57
    wheeldog57
    Fords better idea- let's make every engine component different so people can blow them up!
    chopper99 likes this.
  22. jhuebner
    jhuebner
    Why 2 different styles of cam gears, the new cam and bearings I ordered are on back order so it gives me time to pull and clean the block.
  23. FrozenMerc
    FrozenMerc
    It actually had to do with the cam thrust system in the motors. The '62 and earlier FE's had a thrust ****on mounted on the inside of the timing cover that kept the whole cam and gear ***embly in place. As all automakers do (not just Ford), the engineers came up with a better performing and cheaper system for the '63 and later model years (thrust bearing plate bolted to the front of the block). The fun starts with the aftermarket companies since cam manufacturers only make the later style of cam (which makes sense (cents) since there were many more years and FE motors produced after '62, then before.) However, since timing chains gears are wear items, the aftermarket guys still produced both sets of timing gears, and sometimes they get mixed up.
  24. jhuebner
    jhuebner
    Ja I read about the earlier style FEs, this was my first V8 rebuild before was a couple aircooled VWs, that FE sure sounded sweet before it let loose
  25. FrozenMerc
    FrozenMerc
    Yep, the sweetest motor sound in the world always occurs right before the worst sound you will ever hear.
    "It ran great until it didn't"
    RIP, Yogi.
  26. Judd
    Judd
    you might want to check push rod clearance where they p*** through intake manifold while your at it.
  27. jhuebner
    jhuebner
    Pulled the engine this morning, now the clean up and re build begins
  28. jhuebner
    jhuebner
    Installed the engine Saturday, will finish up Monday and fire it up
  29. Jalopy Joker
    Jalopy Joker
    waiting for good news on rebuild
  30. jhuebner
    jhuebner
    Car fired right up, at 3000rpm oil pressure was just over 60 and at idle was at 25, small issues exhaust leak I have the wrong donut gaskets knew they were going to leak and the gas pedal/carb linkage is binding, will work those out set the timing, change the oil, bleed the brakes..........then go for a road test
