Technical 396 overhaul
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 5, 2021.
  1. squirrel
    Getting there....
    I got a new Torker II to replace the hard to find Weiand Xlerator (however it's spelled) that I sold to a friend in 1990. New repop chrome valve covers should be here tomorrow. I still need to take the two TH400s that I have apart, and combine them to get good guts and case combined with the valve body I like and the switch pitch front pump. And I need to clean the engine bay, it's gotten kind of dirty in the last 10 years since I had it all apart and cleaned things up.
  2. squirrel
    It now has an oil filter, oil to the rockers, valve covers on, and I picked out a carb to use on it--a 650 double pumper that when new, was installed on top of the blower (along with another just like it) on the LS-7.
    I took apart the transmission, and also took apart another transmission that was kind of flaky, but had the Switch Pitch converter setup. This is a different front pump and input shaft, as well as an orifice in the case. I wasn't too sure about the other case and valve body, so I made a new orifice to put in the transmission I'm using, and installed it. It's a cup shaped plug that's press fit in a 1/4" hole, and has an .030" orifice.
    I got the transmission partly back together, I will also do some more modification to the valve body, as it was shifting a bit soft into second, although the clutch plates were fine. I'll increase the clutch feed hole size, and maybe play with the springs for the 1-2 shift valve, which Trans-Go includes in their #2 kit.
  3. birdman1
    birdman1
    My favorite engine, 350hp 396. I put one in a 1969 Chevy C10, in the late 70's. Was a lot of engine for the sto ck th350.
  4. squirrel
    anyways....all back together now. Took some fiddling to get it to run right. The open intake needed more timing at lower rpm, so I ended up putting a Mallory dual point in. I also played with a few carbs before I figured that out, I have the Holley 650 DP on it now, but I'm going to put the Carter 750 back on it and see how it does. Just need to get the hood back on. Oh...and replace that upper radiator hose again, it has a nagging bulge in it at the bottom. And get the cruise control back on, once I finalize the carb.
    fauj, 210superair, Baumi and 16 others like this.
  5. enloe
    enloe
    from east , tn.
    Awesome thread
    squirrel likes this.
  6. 4 pedals
    4 pedals
    from Nor Cal
    Dang Jim, is there anything you can't do? You've done extensive fab work, body and paint building Plan II and Almost Funny, you rebuild your own engines and transmissions, the only thing I can't remember you ever posting is interior work!
    Devin
    Thor1, Desoto291Hemi and Baumi like this.
  7. squirrel
    I did some interior work on a Model T, and made a top for an MG. It's not good enough to share pictures, though :)
    bobss396, Thor1, fauj and 2 others like this.
  8. You’re right,,,,there’s almost nothing that he can’t do .
    I’ve always felt that he was probably in close proximity to the NASA program,,,,or maybe involved with the Skunk works out at Lockheed,,,,,who knows for sure,,,,he’s an enigma !
    Jim Forbes,,,,,,Renaissance man !
    Tommy
    bobss396 and Thor1 like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ask yourself this. Have I ever seen Jim karaoke Anything You Can Do I Can Do Better?
    Thor1, fauj and Desoto291Hemi like this.
  10. Lol,,,,,,Jim is a modest ,,un***uming engineer,,,,hot rodder .
    That’s why he always garners my respect when he post anything here .
    He doesn’t gloat or do a victory dance,,,,,just a simple smile to himself knowing he was right .
    ( I’m ***uming the part about the smile,,,,I’ve never met Jim ) .
    Tommy
    partssaloon, Thor1 and Johnny Gee like this.
  11. 57 Fargo
    57 Fargo
    And Jim can do all of that stuff because he’s not afraid to try. Have to do it to learn how to do it…
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've been within 20 feet of Jim but let him be just like when I see someone famous from TV and Movies. There's nothing I feel I can say without looking like a teenage girl at a Beatles concert back in the 60's. And yes, he does smile.
    bobss396, Thor1, fauj and 3 others like this.
  13. Lol,,,,,,I understand,,,,,,I’m intimidated just reading his posts,,,,,LoL .
    Not too long ago,,,,he actually liked a few of my replies on some threads ,,,,,high praise indeed !
    Tommy
  14. I’ve not met Jim either, but I always find his posts interesting. He is one of the first guys I started following when I got here. I hope to meet him this year at Drag Week, but I also feel like Johnny Gee. What could I possibly say other than Hi, nice to meet you.
  15. Budget36
    Budget36
    But, can he make a tire? ;). Yes, quite a guy for sure!
  16. Budget36
    Budget36
    But what I found out of this world, was driving the Chevy across country a few years back, doing drag week where he couldn’t lift the hood. Did a blower RandR as
    I recall?
    bobss396 and Desoto291Hemi like this.
  17. squirrel
    That would be fine....hope to see you!
    Thor1, fauj, Truckdoctor Andy and 2 others like this.
  18. 427 sleeper
    427 sleeper
    Pure Cl*** and the above response prove's it!!! :cool:
    Desoto291Hemi likes this.
  19. Blues4U
    Blues4U
    from So Cal
    I've met him, he's a good guy. We had a decent talk about nothing in particular, just things like hot rods, and nixie tube watches.... ;)
    Budget36, Thor1 and fauj like this.
  20. blue 49
    blue 49
    from Iowa
    I met Jim briefly at the Meltdown Drags and I felt the same way.
    Gary
