Technical 3G v belt pulley
Discussion in 'The Hokey Ass Message Board' started by topher5150, Nov 4, 2023.
  1. topher5150
    topher5150
    I got a FoMoCo reman alternator from a 99 Taurus. The v belt pulley that I have is from a late 70 Thunderbird which has a tall shoulder on the bottom and covers the entire alt shaft.
    Are there any oem or aftermarket pulleys with a bit of a recess on the back IMG_20231104_095825153.jpg
  2. '29 Gizmo
    '29 Gizmo
    from UK
  3. topher5150
    topher5150
    Time to get my calipers and do some measuring
  4. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Can you just put it on backwards so the shoulder points forward ?
  5. topher5150
    topher5150
    I tried but the shoulder still covers all the threads
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Do you have a friend who owns a lathe. Bout 5 minutes worth of work to remove the boss.
  7. topher5150
    topher5150
    :(nooooo
  8. BamaMav
    BamaMav
    from Berry, AL
    Most alternators I’ve fooled with had the same diameter shaft, Ford and GM. So you don’t have to limit your search to one make, just make sure they have the same shaft diameter.
