Technical 3M 1 step 8000 to eliminate compound buffing
Discussion in 'The Hokey Ass Message Board' started by 57chevymadman, Sep 28, 2022.
  1. Last edited: Sep 28, 2022
  2. oldiron 440
    oldiron 440
    I’ve never been able to completely get away from the wool pad but I have used this system. I use it but the wool pad is still involved.
  3. Happydaze
    Happydaze
    Not exactly, but as a complete novice I've quite recently done trizact 3,5 and the 8k on a da sander followed by foam pads and 2 compounds on a da polisher on single stage 2 pack paint with astounding results.
    The trizact discs seem to last a long time. I've still got the single sample 8000 disc (try before you buy) and have polished a 3w coupe body (w filled roof), 2 doors and trunk lid (which I did 3 times over due to repaint - it was my test panel! ).
    It's considered to be a slower process than the rotary buffer and wool pad, so seasoned pros probably wouldn't be interested, but for a novice able to put a little more time into it, it's fantastic, and not slow (compared to?) really. Fast enough for me, and safe and controlled, with stunning results.
    I used a regular 6" da air sander ($75?) and an electric da direct drive polisher ($225) and foam pads from Lake Country. More expensive da polishers are around, $600?
    Chris
    Budget36 likes this.
  4. Dustin 257
    Dustin 257
    from Dallas
    Personaly the 3m 3 step process has never left me down. White, black, then blue if you need it.
