Technical 3x2 for sbc
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Mar 17, 2024.
  1. bodymanmp
    bodymanmp
    where can you get parts for 3x2 set up??i have the intake and 3 carb cores but need the rest beside speedway and vintage speed??
  2. Phil P
    Phil P
    Although this isn't what you asked for I have been quite happy with my Vintage speed kit.
    Phil
  3. miker98038
    miker98038
    “The rest?” Fuel log, lines, linkage, air cleaners, pressure regulator etc.?
  4. Corn Fed
    Corn Fed
    What carbs are you using? That makes a huge difference in what's required to run a 3x2. 97's are a way different animal than Rochesters.
  5. Joe H
    Joe H
  6. hepme
    hepme
    You named the top two-better stick with proven suppliers. Some advice-if you have only the cores they won't work as is, even with rebuilds. Vintage sells bases that seal, a must, and even rebuilts that are made for this application. Speedway does also I think. Not a cheap deal by any means.
    High test 63 likes this.
  7. Kevin Ardinger
    Kevin Ardinger
    Mikes carburetor parts
  8. Corn Fed
    Corn Fed
    WHAT????? You obviously haven't been here very long or read up much. Vintage Speed is in no way close to being in the top two suppliers. That ramjack is the absolute bottom. I would give up driving carbureted cars before going to him for parts or advice. And yes, I am speaking from experience.
    Speedway also doesn't have the best reputation for carbs either.
    hrm2k likes this.
  9. MCjim
    MCjim
    from soCal
    For what it's worth:
    I bought a set of Rochester tri power carbs, and an old timer advised me the best source for parts was Daytona Parts co.
    Have not yet dealt with them, but will give it a shot.
  10. X 2 for Daytona Parts.
  11. Blake 27
    Blake 27
    I've always been very happy with Hot Rod Carbs (Automotion). I have 30,000 trouble free miles on my 350 Chevy
    with their Rochester three two set up. They're only part time now, so read the statement on the bottom of their
    web site.
    http://hotrodcarbs.com/store/
  12. Blake 27
    Blake 27
    After thinking about my response I remembered that I had an issue with fuel percolation (poor gas).
    So I ordered carb spacers which solved the problem. The kit came with everything I needed, spacers, gaskets,
    longer studs, and nuts.
    Corn Fed and MCjim like this.
