Technical 4:10 Gears with 700R
Discussion in 'Traditional Hot Rods' started by spillaneswillys, Feb 16, 2017.
  1. I am needing to make a decision on my 51 Dodge truck build. It currently has a 4:10 gear with a 700R and a 350 with about 350 HP. I have a 308 rear I could swap out as I mostly just drive. Is there a way to determine the final gear ratio with the 4:10 in over dive.
    thanks
  2. kma4444
    kma4444
    Looks like the OD ratio is .70 so 4.10x.70=2.87. The 3.08 will be 2.156
  3. jimmy six
    jimmy six
    Perfect. You will be very happy with the 4.10's. Later you could go to a 3.70 but that would be my limit. Good luck
    bobwop and gimpyshotrods like this.
  4. Jalopy Joker
    Jalopy Joker
    try sites that have calculators that take in many factors to help figure this out like project33.com
  5. Black Panther
    Black Panther
    from SoCal
    I always Google RPM calculator....first hit is Randy's Ring and Pinion I think...works like a charm. I 2nd the 4.10s with the 700r4...
  6. flynbrian48
    flynbrian48
    I've got 4.10's in the Dana 70 under my Diamond T, with a 4L60 and 6.0 liter LQ4. It's perfect. I don't think, with stock-ish 350, that you'll be happy with the 3.08 gear. Way to long legged gear.
    gimpyshotrods likes this.
  7. hemiboy
    hemiboy
    I have a healthy 383 w a 700r4 in my '34, w 3.25 gears. I don't shift into overdrive until at least 60 mph- the motor bogs. It spins about 1700 rpm in OD at 60. Run the 4.10s!
  8. Rocky
    Rocky
    Classified Editor
    I ran a 700R in a '68 chevy pickup with 3.73s and a 292 six. Worked out ok.
  9. Oldbill51
    Oldbill51
    My old truck has 4.10s and 700R4 with 30ish tall tires. 2000 rpm gets about 55mph. I'm pretty happy with the combo.
    bobwop likes this.
  10. thanks for the input, I will stay with the 4:10s. I like noise so the lower gears will give a nice tone.
    bobwop likes this.
  11. Bigblue61
    Bigblue61
    Ive got a 700R4 with 3.90 gears and 28 inch tall tires. Just went to 4.30 and Im happier than ****. Don't go lower than the 4.10s
    bobwop likes this.
  12. drptop70ss
    drptop70ss
    from NY
    my 47 caddy has 3:08s with the 4l60e, works fine and cruises the highway getting 20mpg. Stock 350 makes plenty of torque, no bogging at all. Same combination as 1994-1996 caprice police cars. Use the calculator to figure your highway RPM at 65 mph if you plan on long distance cruising.
  13. phat rat
    phat rat
    454/700R4, 3.42 gear 2100 rpm at 70 mph. I've been very happy for over 75,000 mi. I've gotten as high as 19.7 mpg
  14. Black Panther
    Black Panther
    from SoCal
    Droptop....is your 47 Caddy fuel injected? With a 3.08 and an overdrive trans its almost mandatory to be efficient. I'd say a highway rpm cruising range of 2200 to 2500 for carburetor engines is sweet. Big blocks can tolerate a taller gear because of their torque. All this ***umes the rod in question weighs 3000 lbs plus...lightweight cars can get away with taller gears for sure...
  15. mkubacak
    mkubacak
  16. drptop70ss
    drptop70ss
    from NY
    Hi, yes I have fuel injection, but i doubt it matters since the cam in that engine is stock and makes plenty of low end torque. 4000 pound car and it moves out just fine.
  17. Timbo405
    Timbo405
    Def. go w the 4.10's - I ran 373's behind a 700 ( MPFI Sm Blk pickup) and the OD rpm was too low. ...and just think how kick *** your first 3 are gonna be!
  18. blue 49
    blue 49
    from Iowa
    My Henry J with a 700r4 , 4.10 gears and 29x12.50x15 tires runs the same RPM as my Turbo 350 with 3.00 gears and 255-70 15 tires when locked up.
    Gary
  19. Gary Addcox
    Gary Addcox
    At 70 mph, with 30" tires, you will be turning 2,255 rpm's with a 4:11 rear. Just right, IMHO.
  20. I will just add that the earlier 700r4 (pre 89/90ish) had less vanes in the pump and due to very low rpms at highway speeds would suffer from a lack of oil flow and fail prematurely. If the vehicle was equipped with 3.42, 3.73 etc then they tended to last longer due to higher rpm.
    Just something to be aware of.
