4-71 blower setup id....who made this deal?
Discussion in 'The Hokey Ass Message Board' started by brandon, Jan 29, 2010.
  1. brandon
    brandon
    got a pic tonight of a 4-71 setup on a boring old sbc..... what is the case / who built said such beast / any info what so ever......let me know.
  2. plan9
    plan9
  3. brandon
    brandon
    check that pic again....no mounting flange :eek: spacer was under the blower , between the intake and the housing. owner / builder bought the setup , but didn't remember who he got it from....it sorta looks like a old pete robinson/george montgomery style case , but a 6-71.
  4. gimpyshotrods
    gimpyshotrods
    The blower case has been "pruned". Some old builders would remove the flange, thus making the top and the bottom of the case more-or-less symmetrical. Vern's was, when they were still doing blowers.
    That one is a 4-71. Matches the one on my bench right now. Still trying to find a 4-71 SBC manifold (for less than what I have in the rest of the whole car).
  5. buick320a
    buick320a
    from indiana
    Looks as if the flange was machined off and a plate adapter boltes to the bottom side of the blower and then sets on a quad manafold
  6. DerricksRodz
    DerricksRodz
    from kentucky
    I have a blower just like the one in the picture. The intake is a crager and is not a 4bbl, it has a rectangle hole then the spacer. Did cragar make this intake like that? Or was the outside mounting tabs machine off to make it more aesthetic?
  7. squirrel
    here's a page from a 1961 cragar catalog...shown is a 3-71 on a small block. Looks like they left the flange on.
    welcome to the hamb
  8. Vandy
    Vandy
    from L.A. Ca
    Tom Beatty did his blowers that way, the blower case was bolted to the manifold from the inside and then the blower was ***embled. I know he cast his own Olds manifolds but I don't know about SBC's.
  9. Deuces
    Deuces
  10. MilesM
    MilesM
    Have not seen a Chevy.
  11. budd
    budd
    i have what might be a related question, i have a dual quad intake for a sbc and a 471, what is the best way of going about finding the best location to mount my blower, front to back? i'm thinking i'll run V belts.
  12. Russco
    Russco
    from Central IL
    I looked for months for a nice intake for my 471 I finally found a true NOS one but it was not cheap at all
  13. budd
    budd
    maybe if someone has this manifold you can tell me the distance from the distributor center to the rear blower mounting holes, that would be a starting point to turn my dual carb intake into a blower intake.
  14. Russco
    Russco
    from Central IL
    It would be much easier to adapt a 671 intake to fit a 471 with an adapter plate. BDS or Hampton or somebody already has them.
  15. gimpyshotrods
    gimpyshotrods
    It is dead-center, side-to-side, and front-to-back. Use the center four manifold bolts as a reference, mill the top flat.
  16. budd
    budd
    thanks, i have a single plane intake as well which might be a better way to go, and i have a nice chunk of 1/2" aluminum large enough to make the plate, would i need a pop off valve if i use V-belts?
  17. gimpyshotrods
    gimpyshotrods
    The belts would likely slip in the event of a backfire. Just set your timing right, and don't worry about it.
  18. DerricksRodz
    DerricksRodz
    from kentucky
    Here is a picture of my unit.. U can see the spacer..
  19. A pruned 471 on a small block does not equate to a boring old Chevy. That is a very traditional modification. Now it it was a little holley blower on a small block I would suggest that it was on a boring chevy.
  20. Kenneth S
    Kenneth S
    471 to 4bbl intake adaptor plate.
    Or you could use a plate on top of a 671 blower intake then set the 471 blower where you want (this plate moves a 671 blower towards the rear) but it should give you an idea.
  21. DerricksRodz
    DerricksRodz
    from kentucky
    After looking real close at my intake I can see where it has been ground and polished back.
  22. gemcityrenegade
    gemcityrenegade
    What about adapting a tunnel ram intake and welding it up>?
  23. jayko77
    jayko77
    This one is not a clone, it was mine.
  24. landseaandair
    landseaandair
    from phoenix
    Figured it had to be, especially with the fabbed carb adapter and spacer plate. Maybe you can do some back tracking to the car?
  25. brandon
    brandon
    btttmf'rs....:eek:
