4-banger compression
Discussion in 'The Hokey Ass Message Board' started by ace43, Nov 2, 2011.
  1. ace43
    ace43
    from Seattle
    I got a question for you 4-banger builders. I have a Model A engine with insert bearing, basicly a "touring engine". I've gone to grade 8 high tensile studs, and I'm wondering how high a compression head I can use on it. I don't want to push it, I just want a good running strong engine.
    Any ideas ? Thanks, ace43
  2. telecustom
    telecustom
    from Langey, BC
    Model B head is 4.6-1.
  3. Saxon
    Saxon
    from MN
  4. TV
    TV
    I'm a Banger Dude, go with a 6-1 and you will be happy.--TV
  5. chrisntx
    chrisntx
    from Texas .
    I'm running a 7:1 Lion Speed head
    Its Super! :)
  6. 4-port Riley
    4-port Riley
    For street use, 7.5:1 will hold up well, just don't let it ping.
  7. morac41
    morac41
    Hi Ace43...I weld filled my original A head and milled the chambers so I finished up with 7.1 compression...worked well .. but its hard on the babbitt rod ends ..only got 15.000 miles before I had to re babbit the rod ends...if your running a C motor with full oil pressure..probally wouldn't be a problem...got to be careful how much money you throw at it as you could build a nice S/V 8 for for less money...Doug
  8. George Miller
    George Miller
    from NC usa
    I would go with the 6-1. 7-1 one will knock on the hills unless you retard the timing or use high test gas.
