1952-59 Ford 4 barrell
Discussion in 'Off Topic Hot Rods & Customs' started by Steady Freddy, Dec 5, 2022.
  1. Steady Freddy
    Steady Freddy
    Morning guys , bought a 4 barrel intake and t pot carb carb # ecz 9510l list#1162 2
    intake # ecz-9425-a . I am wondering if they will work with my original 55 272 distributor . I think if I have the intake off I'll put in a pcv in the valley pan
  2. jimmy six
    jimmy six
    Unless the Holley 4000 has had the Ted Eaton revision it will only work with the loadmatic ignition original to your 55 distributor. You can find the revision on his website. Eatonbalencing.com
  3. 56longroof
    56longroof
    Yes. They should work just fine. Jimmy brought up a interesting point on the distributor. As long as your running the loadomatic distributor you will have no issues. If you ever decide to upgrade to a '57 or newer or aftermarket dizzy then you will either have to swap carburetors or have the tea pot converted for proper ignition advance.
  4. Steady Freddy
    Steady Freddy
