Technical 4 bolt main
Discussion in 'The Hokey Ass Message Board' started by scharleyride, Oct 10, 2018.
  1. I have a Question. Why does every one worry about a block having a 4 bolt main. Just my thinking, If a motor is turning hard enough to brake a main cap, does to bolts to the far out side of center really help. The only couple of broke main caps that I have seen broke in the middle. And the crank was also broke. So why is 4 bolt so important and coast more? If a motor is making that kind of power wouldn't a bridge on the cap be more help than two bolts to the outer edge.
    May be you can help me learn some thing, thanks
    jim snow and chevy57dude like this.
  2. Deuces
    Deuces
    My V-8 block has 6-bolt mains..... :confused::eek::D
    chevy57dude likes this.
  3. saltflats
    saltflats
    from Missouri
    Helps keep the main cap stable.
  4. I've never worried about only 2 bolts per main. I'm running a healthy 406 sbc.
    papadaddio, egads and Johnny Gee like this.
  5. pitman
    pitman
    Bolts are, esp. when torqued, a stiff spring. Four per cap, 2 at an angle, serve to stiffen the ***embly.
  6. deucemac
    deucemac
    Some people touting 4 bolt mains tend to forget or ignore what happened to 4 bolt main Chevies when first raced in NASCAR. It seems that the 4 bolt caps were thinner in the center and when dynamic forces came into play, the crankshaft would be forced down ever so slightly causing the a ring to pinch the journal and bang , lost motor. They cured the problem by counter boring the block and main caps and inserting stainless bushings that prevented cap walk. The street and drag race guys never saw that because they never experienced long periods of high speed dynamics. The best 4 bolt blocks are ones with aftermarket splayed main bolts that draw the bottom end together and counteract the high speed dynamics. The 4 bolt in my El Camino became dreadfully tired and needed sleeving which I didn't want to spend money on. I bought a '69 Chevelle 300 hp 2 bolt block and for over 270,000 miles , beat the snot out of it. It's tired now but never a hint of main or rod bearing problems. In my opinion, 4 bolts are nice but a well built 2 bolt delivers all you need.
    papadaddio likes this.
  7. Boneyard51
    Boneyard51
    Back in the previous century, when I was building sbc s I read everything I could about them. Don’t chisel this in granite, but I belive it was Smokie that said you don’t need four bolt mains till you get over 600 horse power.... and very few people can get 600 out of a small block. Now before you jump on the horse power figures ... this was in the late seventies.
    But 600 back then, is the same 600 today.
    Just my recollection.
    Bones
  8. deathrowdave
    deathrowdave
    from NKy
    In my Chebbie days the best blocks I found were from C60s . Under the timing cover was .020 not .010 cast into the block . High Nickle 4 bolt block . There have been many 2 bolt blocks regularly spun to 10K . I really would not worry too much about finding and spending big money on a 4 bolt block , it’s not needed for the driving habits 99.9 % , most of have lived to see . I have a ***mins 4 cyl Diesel in my Power Wagon daily driver that I bet is getting way more pounding on the crank every day than most gas engines will see in a lifetime , it’s a 2 bolt block with 2 1/4 in wide bearings . Don’t stress over stuff you don’t need to .
    papadaddio and egads like this.
  9. Because the extra bolts sounds cool
    Science has proven they add 2 million HP
  10. DDDenny
    Another famous saying from the peanut gallery.
    "All four bolt main blocks came from Corvettes".
  11. Bandit Billy
    Bandit Billy
  12. tomcat11
    tomcat11
    Splayed caps actually work. Straight 4 bolts weaken the main webs. Studded 2 bolts are plenty strong. There are differences in factory cap material (Nodular Iron vs Grey Iron) No offense, but that High Nickel production block myth was debunked by people that worked at the foundry.
    deucemac, thirtytwo and squirrel like this.
  13. deucemac
    deucemac
    Yep, especially 4x4 crew cab Corvettes. Just like "oh, you have an 010 block! They are all 4 bolt!"
    tomcat11 likes this.
  14. tomcat11
    tomcat11
    Don't forget the convertible coupe cabs!
    deucemac likes this.
  15. Fordors
    Fordors
    I agree with tomcat, the current GM race blocks use nodular main caps but they don't mention the old Bow Tie ( I think it was late '70's- early '80's) High Tin blocks anymore that were available under p/n 366246 and there was also p/n 366287 that had siamesed bores and thick cylinder walls.
    I always found it interesting that Jenkins or Yunick never mentioned the 010/020 thing, I imagine that was so they could keep a ready supply of blocks for themselves. ;)
    Vizard did mention it in a book of his and he says the percentage of tin was 10% but Google has a metallurgical paper written by a professor that says tin can be alloyed with cast iron on the order of 1 or 2/10's of a percent. That is a far cry from ten percent.
  16. deathrowdave
    deathrowdave
    from NKy
    Again thanks for a correction notice. I quess I fall in the you can’t fix stupid line , concerning nickel content of a SBC . Im sorry if I mislead anyone, just p***ing on what I was told, many moons ago. I haven’t touched any BowTies in years , I suspect it is because there are so many NASCAR , High Nickel blocks floating around , I just wanted to be different and try an engine out with the distributer on the wrong end of the cam and it only has a lowly 2 bolt main cap block also. It really seems to work as well as the high dollar stuff , I looked for many years ago . Again don’t stress the small stuff , dare to be different and use what you have, all for the cause of having fun with your car .
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bandit Billy likes this.
  18. Bandit Billy
    Bandit Billy
    At least you got 10 bolts holding that crank, my V-8 only has 6
    deathrowdave likes this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    12 bolt :D
  20. Bandit Billy
    Bandit Billy
    ^^^bragger :rolleyes:
    Johnny Gee likes this.
  21. bobss396
    bobss396
    All of the above, otherwise a 4-bolt block is little more than bragging rights. My 355 is a 2-bolt block and I used all ARP hardware to ***emble it, **** rods with 7/16" bolts. We used 2-bolt blocks in the stock cars, wound those up to 7k a couple nights a week.
  22. Deuces
    Deuces
    .....and trucks!...
  23. Ned Ludd
    Ned Ludd
    6-bolt mains on my dad's 1975 Mercedes-Benz V8, too. Four vertical and two horizontal.
    I was surprised to find 4-bolt mains on the little Alfa Romeo Alfasud flat-4. Unusually for a horizontally-opposed engine the iron block is one piece, with conventional bearing caps except in that they are cross-bolted through the bottom part of the block.
    Deuces likes this.
  24. F.O.G
    F.O.G
    from Pacific,Mo
    Big 3 did not spend many $$$ making 4 bolt mains just to spend the money or train engineers, they ARE
    more stable. As many have stated 2 bolt mains are up to the task 99.9% of the time. I certainly would not
    take a good running 2-bolt block out of a vehicle to put in a 4-bolt just so I could say I had one.
  25. squirrel
    Chevy made far more truck 4 bolt main engines, than car 4 bolt main engines. What is it about trucks and high performance cars, that would make them think the extra parts and machine work of adding extra bolts, would be worth the effort?
  26. F.O.G
    F.O.G
    from Pacific,Mo
    Something did.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Torque via gear reduction =?
  28. Thanks for all the replies. I just see motors for sale and people want more for a 4 bolt than a 2 bolt and wonder way the different s and is it really worth more.
  29. Boneyard51
    Boneyard51
    If I was going to build high horsepower, which translates to high bucks, I would invest a little more at the start by selecting a four bolt main. A small cam, headers, high rise, Four barrel.... two bolt would be fine.
    Bones
    Deuces likes this.
  30. DDDenny
    GM's marketing dept.
    Remember "Win on Sunday, Sell on Monday".
    Deuces likes this.
